Can the Oppo play DTS-HD in a MKV file?
post #3121 of 10417
4/21/11 at 3:46pm
I have a question on hooking up my 95, it should be delivered tomorrow. I have a Pioneer Elite SC-35, I'm sure many of you have nicer/higher end equipment than this that are big into two channel stereo. I've never been a big two channel stereo guy, I'm happy with my iPod hooked up with MP3's @ 192 CBR for stereo listening. However, I want to get into high end two channel audio. The speakers I have are front l/r Definitive Technology BP 7004, Center C/L/R 2500, rear l/r BP2X. Should I use the analog outs on the BDP-95 to the back of the recevier? If so, recommendations on cables? I know good analog cables make a difference. I was just going to use the HDMI out on the 95 but after reading all this about how well the analog outs really are makes me want to hook it up the best way possible. Any recommendation on something to test the audio? DVD-A disc SACD? I listen to a lot of classic rock...
Don't discount measurements. If the measurements show a problem odds are you will hear it (or see it), even if you can't pinpoint subjectively why it isn't "right".
But once the measurements reach a certain threshold of "goodness" it is unlikely that any additional improvements found in the lab will correlate well with what you hear (or see). Good bench test measurements are necessary but probably not sufficient -- basically because there's no practical way to measure everything. --Bob |
I'm new to the aspect of streaming content (ie. BD, SD-DVD, FLAC, mp3, WAV, etc.,...), and this has probably been posted previously. However when I stream content (BD movie for example) to the BDP-95 via-EtherNET are you able to engage on-board video-processing to it as well?
I am aware that this is the forum for the OPPO 95. I just wanted to share something I discovered with the knowledgeable people in this forum since it was the 95 that led me to this discovery. After listening to the pristine sound of the 95 for a month and a half, I came to the conclusion that something wasn't quite right with my speakers. I took them apart and I treated every unsodered connection with Stabilant 22a. (It's a contact enhancer.) I was so impressed with the results that I treated everything from the moving coil pins to the speaker connections and everything in between (using minute amounts).
It's very difficult to do a before and after comparison but my experience was that the overall sound improved, especially the high end. It was more open, detailed and extended! I would suggest that you do your own research. This product enhanced my sonic enjoyment almost as much as the OPPO 95. Sandro ![]() |
Has anyone had issues (pops/noise) with Flac files? I have a few issues with 24/96 files and more with 24/192. My problems occur with flash drives and HDD's conected using either USB or E-Sata.
I have tried using foobar2000 and DBpoweramp (with file verification) to re-convert comercial files from HD Tracks and Linn to a lower flac compression setting. The lower compression settings help a lot. Some tracks which crashed the player now work fine. Others are "almost" perfect - 1 hiccup instead of 3-4. The files play without error on my PC using DBpoweramp. I have sent one sample track to Oppo for examination, but I would like to know if anyone else has similar problems. |
] . I found a pdf that mentions different ways of measuring jitter so that may clarify
and feel obligated to give unjust credit. But hey I could be wrong on that one, and we are just privileged to have so much great gear. The Oppo team hit it out the park with the 95 and has change the landscape of what's highend, and if you want!" how much" it cost to get there. This isn't trickle down left overs! ,but an amazing achievement regardless of its price
