AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-95 Owner's Thread
Official OPPO BDP-95 Owner's Thread - Page 138
post #4111 of 10429
Another thing to try as a diagnostic: see if you get the same results on HDMI2 as on HDMI1. That will tell us whether Qdeo processing is a factor.
I tried it and got the same results, although slightly better than on hdmi 1. Setting the TV system to NTSC would be the best solution for this problem.
Since no one else has mentioned this I thought I would put my 2c in. I had issues with choppiness in my video until I researched 1080p/24. Due to the reduce frame rate in the 24fps you will see chop on slow pans, depending on the filming techniques it may be very distracting. I found once I set my player to 1080p max resolution, rather than 1080p/24 the issues with choppiness went away.
I already tested that and it didn't make any difference with the option '1080p/24' off. The choppiness occurs in faster parts, not so much in the slower.
post #4112 of 10429
Originally Posted by mal01 View Post
Thanks Bill, i will probably just stick with the 83, the main difference in the 83 and 93 is what 3d? and i don`t care about that right now.
In addition to 3D there's enhanced user media support -- such as high bit rate FLAC files, Netflix (et. al.) streaming, dual output HDMI (one to the display the other to the AVR), Wifi networking, and enhanced analog audio output quality (even more so with the 95).
The main thing that's lost is SD-DVD conversion to 1080p/24 output. You get 1080p/60 instead.
--Bob
post #4113 of 10429
--Bob
I guess i somewhat oversimplified it I use a Roku for Netflix and have my 5508 on the net with a wireless bridge so i think i`m good there. What is the benefit of the dual HDMI output? I knew there were new Oppo`s out, but didn`t really think i needed one so i haven`t done any research what the new ones do better than the 83 in terms of pure performance on blurays, manly movies
post #4114 of 10429
Dual HDMI is for 3D users who have AVRs that won't pass 3D video.
If you are happy with the features on the BDP-83, then there is no need to upgrade. BR and DVD performance are very similar.
-Bill
post #4115 of 10429
-Bill
Thank you! I`ll just keep saving for my height speakers
post #4116 of 10429
I've been really enjoying my Oppo 95 (my first bluray player) over the weekend but can't help but wonder if I've managed to "blow" my subwoofer or if everything sent to the LFE blends in so seamlessly that I just don't notice it. As an example, the stomping of the tripods in The War of the Worlds was not the deep thud it was more than a little lacking. I've already set the crossover to 100hz for my poor B&W VM1s.
Do most people turn the LFE channel up by a few db or have I managed to accidentally murder my subwoofer with the very unexpected bass in X-Men?
post #4117 of 10429
If you are using the analog 7.1 output from the Oppo-BDP95 and if you haven't done so already you'll need to properly boost the subwoofer level 10-15+db. Did you calibrate your system using a Radio Shack sound meter?
Techlord
post #4118 of 10429
Techlord
I'm an Antimode 8033c for my LFE and YPAO for the rest. I will boost the LFE by 15db and then do a bit of "tweaking". Many thanks for the help, I just love using this incredible machine!
post #4119 of 10429
I expect to receive a 95 sometime tomorrow and had almost pulled the trigger on Tridane's multiregion DIY kit - PRO version when I downloaded and read the install instructions (I installed the kit in a BDP-93 which I sold on eBay recently . . . rather quickly I might add). Unlike the 93, however, with the 95, you must also remove and replace two boards, the audio and power supply, during the installation which I must admit being rather hesitant to do. Is anyone who has gone through with this willing to share their experience? Fee free to send me a private e-mail.
post #4120 of 10429
Your welcome, I only needed to boost mine by 9db.
Techlord
post #4121 of 10429
Greetings and thanks to everyone for all the good information.
I ordered the 95 around page 50 and received it around page 90.
You guys are great and Oppo should be thankful for all your help.
I had a Sony 555es and replaced it with the 95.
You guys can argue about this, but it did not sound as good as the Sony for about a week of steady playing of only 2 channel. Then it improved- and not just a little- but alot. What is very impressive is the improvement of the redbook titles. CDs that I had a hard time enjoying are now a pleasure to hear. I am pretty tight with my money and was going to return it --but it is a very good deal and I have not even downloaded the hi-rez yet--and that's one of the reasons I bought it.
Side note;
I bought a Samsung 27" 1080P TV from Costco for under $300.
Thanks again
Bill
post #4122 of 10429
It's more fiddly and time consuming rather than difficult per se, there are a lot of screws to remove! You should be fine as long as you are careful.
post #4123 of 10429
Originally Posted by alebonau View Post
hooked up the 95 and been enjoying it since yesterday
both over hdmi and via balanced XLR with my denon avp. very nice !
some feedback though perhaps will be listened to for forth coming improvements. this is only since limited use keep in mind.
1. XLR balanced connectors, these are mounted upside down on the back of the 95 ! means the locking levers on the cables end up upside down. makes awkward in connecting up and disconnecting. and also is very non standard !
2. The eject button on the front panel of the machine needs to be illuminated ! all other buttons on the front panel are illuminated why isnt the eject button. makes hard to find the button in low night especially since it is the one button most likely used on the front of the player.
3. because of the centre mount drive and low profile case of the player. the display has ended up on the side. squeezed between the power button and the disc drawer. perhaps consider moving the display under the disc draw. eg on the sony 5000es and denon 4010. display will then be a lot easier to read on the oppo then like on these other players. perhaps look at changing the way HR:Min:sec is displayed as elapsed time so easier read
4. Make sure logitech updates the harmony 1100i database for the bdp-95 player. even though its listed on the data base. if you select the player all functionality is greyed out. have to select the 93 player.
otherwise this is a very nice player overall. and very happy with it in use and its result
just to add to my previous feedback, and additional point as per below :
found something a little oddish on the 95,
you switch it on, open the disc draw, put a disc in but till the 'open tray' icon pops up on screen you cant close the disc tray, can jab the button as many times as like.
overall the 95 is a bit mroe sluggish doing something or the other at start up and shut down I do think vs the 5000es and the denon 4010 I had before that were a little more quick and snappy on start up and shut down. nothing major just a something a little niggly.
post #4124 of 10429
The 93 and 95 take about 30 seconds to boot up when you turn them on.
They are specially programmed to open the tray early in that if you command that. But they can't respond to other commands, including Tray Close, until after the boot up cycle finishes.
--Bob
post #4125 of 10429
--Bob
thats pretty slow, both the denon 4010 and sony 5000es are ready to go as soon as switched on. can open shut disc draw etc nothing bothers them.
god knows what the hell is going on with the 95 and what its doing for all that time !
very odd !
post #4126 of 10429
very odd !
There's a lot more going on when the 95 boots up as it is loading at least some of the modules (for lack of a better word) needed for the various streaming apps. Neither the Denon 4010 nor the Sony 5000es has all this extra stuff happening.
post #4127 of 10429
well the sony is a 3 year old player the denon 2 years old universal, and both switch on and boot faster. so much for progress .
I dont give two hoots for streaming apps. I'm not using any so why should they be needed. they can surely be booted in good time when someone actually wants to do some streaming
same with shut down process. if not streaming or anything I dont see why it has to do whatever its doing when shutting down. rather than older players that just shut down promptly without any dithering about as this seems to do.
something surely oppo can improve on. yeah no its not the end of the world but it would make the player a lot more snappy in use
post #4128 of 10429
Send your feedback to OPPO. All we (the beta testers) can do is explain to you what is behind the bootup / shutdown times.
The streaming apps are there because the competition offers them (it's harder to sell a player that costs more and doesn't have at least many of the "checklist" items the less expensive players have) AND lots of users complained about the lack of streaming apps in the previous generation of players.
FWIW, we have asked OPPO to explore if they can lazy load anything that isn't absolutely required when booting up as that would obviously speed up the boot process. It would be a nice bonus for those of us who don't make much use of the streaming apps (I give them limited use, mostly just due diligence as a beta tester). I don't know enough about the architecture of the player to know if they can do this or not and they probably have higher priority items to tackle first anyway.
post #4129 of 10429
When a friend loaned me his 95 to demo I did not find the load times any different than my 83SE which is fairly quick IMO. I had no connections for streaming any music so I'm not sure if that matters. I was just playing DVDs, Blurays, CDs and SACDs.
I found that when I powered up the 95 using my Harmony remote then hit eject the tray opened right away. I then push play and CDs and SACDs started playing just about right away. I never did time it but I found the timing very similar to the 83SE. Maybe it was a longer time but I'm in no hurry. I just checked the 83SE and on power up the tray opens right away put in a SACD then push play and about 5-7 seconds the disc is playing.
Bill
post #4130 of 10429
Hi all!
I just got my new BDP-95 set up over the weekend and it seems to preform exceptionally well, as reported. I do seem to have one glitch though when trying to connect to the internet.
I am connecting wirelessly through my home network. The network accepted my password just fine and the Oppo shows I am connected at a 90% signal strength. The connection test shows that I am connected. The Oppo notified me that new firmware was available but when I tried to download it the Oppo would not connect to Oppo's server.( I eventually installed the firmware manually) I am also having the same problem trying to connect to Netflix.
I am using an Apple Time Capsule router. Does Oppo not play well with Apple? Has anyone else had a similar problem ? Any suggestions on how to connect will be greatly appreciated !
Sam
post #4131 of 10429
This sounds very much like a problem reported by others who have an outdated modem -- particularly older DSL modems.
Often the ISP updates the system at their end but doesn't update customer modems until they get a complaint. Check with your service provider about swapping out for a newer modem.
--Bob
post #4132 of 10429
Thanks for the reply Bob! My modem is kind of old. I will call the service provider and see what they can do.
Sam
post #4133 of 10429
--Bob
Sounds like you hit this one on the head. I called my ISP to see if they would give me a new modem and guess what? They are sending a new one out at no charge! Again, thanks for your help! I'll let you know if this solves the problem, I have a feeling it will.
Sam
post #4134 of 10429
Can someone confirm whether the 95 could play flac files via network off a NAS ? If yes, how's the interface ?
post #4135 of 10429
Yes, if the NAS has DLNA.
The media file browser is very basic, and is illustrated in the online manual.
-Bill
post #4136 of 10429
Yes it can. I'm using a Western Digital (My book live) model, and I'm very please of the performance.
post #4137 of 10429
What makes the original report so unusual is the assertion that the problem is only happening when the content has a significant component at the highest frequencies (e.g., 15KHz or higher sine waves).
If you are getting distortion for content across the wider range of frequencies down to high bass (whatever your main speakers are being asked to reproduce) then that makes it more likely you are simply clipping the analog input to your pre-amp, or AVR. I.e., that the input in your pre-amp or AVR is not designed with the headroom to handle the higher input voltage peaks that happen when you add a positive output volume trim in the player.
Different pre-amp and AVR designs will have different headroom characteristics on their analog inputs.
My D2v has good headroom but it is still the case that the analog output of the player is about +1.5dB higher than the D2v is expecting even when using 0dB trims in the Oppo. The D2v has an analog input level trim setting that adjusts for that. In the first instance this makes the analog audio input closer to exactly matching the audio level the D2v produces with HDMI audio input from the Oppo. But I think it also refines the analog audio path a bit. (There is probably some listener bias in that last statement.)
--Bob
Bob:
I am using XLR and MCH outputs of the 95 into the D2v. The analog trims in my D2v are still set to -1.5dB, a left over from the 83SE. The subwoofer trim value in the Oppo is still set to +5dB. Are these still valud values, especially the XLR trim values since they produce twice the analog voltage of the RCA outputs?
post #4138 of 10429
-Bill
oh wow so with the 95, which should have a decent to great analogue output stage, SOTA DAC, differential XLR output and play network files of standard to high res, drop in a nice volume control like GoldPoint, and you have a simple yet decent front end !
Did I miss anything or am I overly optimistic? If I am correct then is there a reason to get stream players like Squeezebox, except for may be a better interface?
It sounds too good to be true for those like me who wants a simple setup, not overly costly and yet with certain quality.
post #4139 of 10429
I thought you were from the Land of Contintment? This player is one of the fastest, if not the fastest BRP on the market today...and yes it does a lot more than just play BR. You could just leave it on if it bothers you too much.
post #4140 of 10429
http://www.6moons.com/audioreviews/nuforce16/2.html
An interesting tit-bit ...
"Alex Dondysh designed both Oppo boards for us. We cancelled planned work on the ESS Sabre-fitted BDP-95 to really focus on two BDP-93 versions with their Cirrus Logic DAC. A minimal-phase analog reconstruction filter rolls off gently to minimize phase shift (these filters are different for the standard and extreme board). Supported sample rates are 44.1, 48, 88.2 and 192kHz from 16-24 bits. All eight channels are re-engineered. We use a highly regulated and filtered local linear power circuit but retain Oppo's main PSU. We bypass the muting circuitry and add high-performance op-amps, OPA 2134 for the standard board and LME47960 for the extreme. With either board the CS4382's originally differential output is run in single-ended mode to undo the stock unit's cancellation of even-order harmonics*. The standard board's sonic goal was for 12AX7-type triode characteristics without tubes. It's for the listener who favors a minimalist 300B amplifier-type system."
A cynic might say that your $400 essentially just buy you differently distributed harmonic distortion
