Thanks rdgrimes and Bob. I was afraid of that. I've had the Oppo for just about 10 days beyond the 30 day trial period, eeks.
post #5731 of 10456
9/11/11 at 9:07am
FLAC files work fine all day long. Update the software on your unit, it sounds like you are running out of date code. Try that first, before going any further with other remedies. Then, report exactly what software version your Oppo is running.
ManWithAPlan,
The Firmware version is BDP9x-52-0707 which is the latest version. Using Foobar as a media server has solved the problem. The Oppo is now showing all my Flac files. I think the problem was that I was trying to access the files directly off the server with Windows Media Sharing (using Windows 7). Which is odd, but I am good now. Oh..and I forgot to mention how much I love the BDP-95. I used to own a Denon DBP-2012UDCI and that player was good but no match for the Oppo. love it!!! |
ManWithAPlan,
.... Using Foobar as a media server has solved the problem. The Oppo is now showing all my Flac files. I think the problem was that I was trying to access the files directly off the server with Windows Media Sharing (using Windows 7). Which is odd, but I am good now. ... |
LOL! It's the giant now and bad as I hate to say it, told you guys so!
