AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-95 Owner's Thread
Official OPPO BDP-95 Owner's Thread - Page 284
post #8491 of 10431
Originally Posted by scolumbo View Post
Is your DLNA server configured to see the files on your attached drive? It may be that it is set to only see the files on your laptop. Any files contained within the library of the DLNA server should be visible to the Oppo, assuming they are in a file format supported by the Oppo.
I dont know. I just enabled DLNA in my Sony Vaio. thats all I did and then clicked network on the oppo to see what came up. The oppo could see files on the computer but didnt see the usb attached drobo s. maybe it needs time to populate?? Just because the computer can see the files doesnt mean the oppo can even if it is attached to the computer. I'm gonna ask drobo. They will probably tell me I need to buy the drobo fs. I'll test it with a regular WD external drive and see if it can recognize it.
post #8492 of 10431
Going out on a limb here, but isn't a NAS required to be plugged in directory to the network via lan cat cable? Mine is plugged in directly to a switch connected to the router. My 93 sees it fine. Your Sony is preventing the network from seeing it.
post #8493 of 10431
i have mine in my rack which is right next to my TV. Sometimes i hear clicking noises and it can be a little annoying if there is a quiet scene in a movie for example. Nothing too crazy but noticeable. I just like having the rack right there so i can access it easily...and look at it
The clicking sounds like the muting relays. They should NOT be cycling during normal playback. If they are cycling you should hear the audio cutting out. Are you sure the sound is coming from the OPPO?
If you have something in the front USB port, check the little flap you pull open to reveal that port. It may be ticking against something.
--Bob
post #8494 of 10431
thats probably right. I had 2 choices, a networked drive with 10 TB's or a USB drive with 10 tb's. There wasnt an option that had both. I may have to buy a drobo fs or some other nas unit. Woohoo. I'll put it in the rack and plug it into the switch and the oppo should be able to see it (as long as it has twonky on it I think). i can play with media monkey and foobar too which require the wasapi plugin for playing the bits perfectly and avoiding windows corruption of the music.
Ah, maybe if i load up some music in media monkey from the usb connected drobo the oppo could see it then?? have to try that too. Honestly I never thought i would use dlna much. I like everything hard connected no matter what it is which is why i was trying to find a nas type box that could connect via usb and have networking capabilities. Looks like Im gonna get sucked into dlna land. If it works well I guess that will be ok but am always nervous when things arent hard connected which tend to be unreliable. 100% uptime is what I like!
post #8495 of 10431
There have been reports of heat expansion and contraction causing clicking sounds coming from the display. That's another possibility.
...and look at it
I like to look at the screen most of the time.
post #8496 of 10431
--Bob
I'll make sure I keep track and document. I think one time it was when i tried to play pink floyd live at pompei video in PAL. I bought the directors cut in ntsc recently and it was great. The couple times it happened it was clicking quite a bit and I suspected it was working hard on trying to read what I was throwing at it. But it was playing it and i was watching and enjoying I just heard some clicking.
post #8497 of 10431
I think you nailed it. I'm no networking expert, but it would seem that the NAS would have to be connected to the router via ethernet to be seen on the network. My NAS is also connected through a switch to my router. I have other HDD's attached directly to my pc. The Oppo can see all of these drives through the media servers I use.
post #8498 of 10431
Since the Oppo can't see network shares directly, I believe DLNA is your only choice unless you store everything on drives directly attached to the Oppo. While DLNA can be flaky at times, if you have everything hard-wired and don't have to rely on wifi, it can be fairly stable. I've had very good experiences with Twonky, MediaMonkey and Foobar.
post #8499 of 10431
I concur. Hard wired will make things better. And DLNA can be quite flawless
I've been using Twonky on my somewhat old Qnap since the 93 came out and it handles pretty much everything I throw at it with ease - and this thing just has a 500 mhz processor and 128 MB of ram. Before I got around to fishing the cable to the right place I was using a wireless->ethernet hub and I could stream everything except for hi-res multichannel flac with no problems (even that would be okay if the network was otherwise silent).
Another thing a NAS can do with DLNA vs USB is have RAID. As far as I know RAID arrays won't be accessible to the Oppo with USB.
post #8500 of 10431
I use the wasapi plugin for MediaMonkey and Foobar. I haven't found anywhere in Twonky where that is an option. I know it's important to ensure bit-exact output when playing audio through a pc soundcard, but I've never been clear if it's really necessary when sharing audio through a media server. To be safe, it's one of the reasons I mostly use MediaMonkey and Foobar for streaming music, and I use Twonky to stream video files.
post #8501 of 10431
Originally Posted by jimshowalter View Post
The fan on the Oppo BDP-95 is the loudest noise in our listening room. Not that it's all that loud, but it's the loudest in a quiet room.
I'd like to make it stop making so much noise, but haven't come up with a good solution yet.
I'm toying with the idea of removing the fan entirely, gluing heatpipe pickups to the CPU and whatever else needs to be cooled, and running the pipes out the fan hole to a massive sink. Heat would definitely be conducted out of the chassis, but I'm worried that general air movement cools everything, compared to just cooling particular components. I'm also not sure what other components to cool other than the CPU.
Does anyone have thoughts on this? ("Don't do it." isn't a thought: that's just a reaction.)
Do it! Then report back in a few weeks to see if it worked. Hope the unit isn't still under warranty, 'cause this may void it?
I have the 95, and the fan noise is 'mildly' annoying, especially since I listen to a lot of jazz (many songs have quieter passages) and can hear the fan noise. Usually it's between songs mostly. I 'had' the 95 in my equipment rack with 2" of clearance on the sides and about 3" on top. For grins, I've now moved the 95 to the top of my rack, so there is nothing to the sides or above it. The instances of the fan turning on now have decreased markedly! Just wanted to share my testing/experience with the fan noise. Best of luck.
post #8502 of 10431
I recently disconnected, moved, reconnected the player and updated the firmware to the latest version. I have picture, but no sound at the analogue outs(Stereo(rca and balanced)and multichannel).
Has this happened to anyone else? Possible cause and solution?
The mute is off, and I tried volume at fixed and variable.
I also Bypasssed the pre-amp(to rule out the pre).
Any help is appreciated
PS I have no digital processsing (other than the oppo) for sound.
post #8503 of 10431
Perform a reset to defaults, then power off and unplug the player for a minute.
Power back up and re-enter your speaker setup stuff.
post #8504 of 10431
I just received my Oppo 95 last night. I have some questions/observations after setting it up.
I have the latest firmware installed.
The movies I have tried so far all seem to start up out of sync in the beginning. The movie studio intros always appear part-way into the intro as if the player started showing the audio/video after the disc already started playing. This has an adverse affect on one of my movies (Zulu). In Zulu, the opening credits and music are out of sync and the beginning with Richard Burton's voice reading the letter is also delayed.
Is anyone else experiencing this and if so is there a fix.
I have a Bose V20 home theater system. It is HDMI 1.2 and from what the Oppo manual says...I'm using only a Monster high bandwidth HDMI cable for both video and audio signals. The manual says high resolution audio formats cannot be transmitted through coaxial or optical cables. This surprised me as I was using an optical cable for sound with my old Panasonic and thought I was getting the high resolution audio formats.
I would appreciate hearing your feedback. Thanks
post #8505 of 10431
...snip...
Coaxial and optical cables don't have sufficient bandwidth to handle the high resolution audio formats.....although, I have to say it still sounds pretty good.
post #8506 of 10431
I'm going to give it a shot. I just wish I knew what components to focus on other than the CPU and (probably) the video chip. I may rent an IR camera to look for hot spots. Shame Oppo hasn't already dealt with this. The fan *is* noisy, in a proper listening room. I've sent them a suggestion to deal with it in a future version, and the replied that it was sent to engineering, which is nice.
Ours is second from the top on a Metro rack with lots of clearance, but the bottom of the rack is occupied by an Anthem P5, which outputs a lot of heat. (Google for martin logan system 420.)
post #8507 of 10431
My feedback...send the 95 back and get the 93 if all you are using is HDMI out for your audio. The primary diference between the two players, other than $500 is the analogue audio out. Complete waste with your hook-up.
post #8508 of 10431
I don't recall any recent sync problems. There are people here with more experience diagnosing problems that I'm sure will help you tomorrow.
Is this system designed to interface, using HDMI, with players from other manufacturers? Your problem may be a setup issue involving the V20.
Do you mean you have connected the OPPO to the V20 with your HDMI cable. Which OPPO HDMI port are you using?
True. It's an optical cable band width restriction.
You were getting improved (I think it's a higher sample rate.) standard (core) audio, not Dolby TrueHD, and DTS-HD Master Audio.
Look for diagnostic help here or call OPPO. One thing you've gotten with your OPPO purchase is outstanding customer support.
Note: Once you get your sync problem sorted out, you'll also want to find out how to keep the V20 system from trying to process your video signal from the OPPO. Bose tends to think it's their way or the highway.
I assumed that you've been using a Blu-ray player, but when I down loaded the V20 manual there were instructions for a DVD player but no mention of Dolby TrueHD, and DTS-HD Master Audio. There also was no mention, that I could find, of LPCM HDMI audio output. I was looking at the og_ls_vclass.pdf file from Bose for the Lifestyle V20 and V30 home theater systems. Maybe I missed them.
Enjoy.
post #8509 of 10431
just curious, why did you get the 95 as opposed to the 93?
Does your Bose receiver have a "lip sync" or audio delay setting?
post #8510 of 10431
I didn't realize that and would never have known if you didn't post it here.
post #8511 of 10431
Enjoy.
Answering your questions above....
I assume so. Both HD formats were still on the market when this system came out. I think Bose didn't want to take sides and left what player to use up to the consumer.
I'm using HDMI 1 per the instructions.
That's an interesting point but since the system was designed to work with players of the consumer's choosing I wonder if that's really a problem.
I was using Panasonics prior to the OPPO. I don't believe the V20 has LPCM HDMI audio output.
post #8512 of 10431
I thought it was the later (and better) model. I don't think the Bose system has any way of setting up an audio delay.
post #8513 of 10431
With the $500 you save by going with the 93 instead of the 95, you could buy yourself a nice up-to-date receiver with HDMI 1.4 support that will handle all the latest audio and video format and give you room correction to boot. You could continue to use your Bose speakers with the new receiver and consider upgrading those in the future as funds permit.
post #8514 of 10431
See OPPO's comparison chart and recommendations: http://www.oppodigital.com/blu-ray-b...5-Compare.aspx
-Bill
post #8515 of 10431
Any recommendations on the receiver? I just got off the phone with Crutchfield discussing the sync issue and mentioned the unit might be overkill for my setup. Since my movies all start up out of sync and I just got the unit I can return it for a replacement or a refund. So now I'm thinking I should switch while I can.
While I'm at it...I have a Sony KDS-60A3000 for a TV in case that matters. I love the television's film quality image.
post #8516 of 10431
Personally, I'd start looking at options from Denon and Onkyo that fit your price range and go from there. Discussions of specific recommendations and such really belong in the AMPs, Receivers, and Processors forum so we don't get too far off-topic here.
post #8517 of 10431
Thanks...I understand and have already started browsing there.
post #8518 of 10431
I will be getting a 95 with in the next few weeks and I'm looking for a little advice, the major of playback will be via mkv and flac files and was looking for the best way to approach this, if a NAS drive is connected to the router can the 95 see the drive directly without having a computer on or do I use a usb drive which would then have to be disconnected every time to copy files to it or can a pc see a usb drive connect to the 95 through the network in order to copy files. I am currently using a WD media player connected to the D2 and would like to get rid of ii and replace it with the 95. Which is the better option the NAS or USB drive or an esata drive seeing as the 95 is only usb 2.
Any advice would be greatly appreciated!
post #8519 of 10431
Following up on my issues. It appears the Bose system is bottlenecking the signal coming from the Oppo which explains why every disk starts up "late". By that I mean the studio logo (20th Century, Universal, Paramount, etc.) video and sound appear on screen "after" they have already started by about a second or so. But the movies play fine.
I tried connecting the Oppo directly to my television and even though I cannot hear the sound I can see the video portion starting up normally.
I've decided to keep the Oppo 95 and upgrade my sound system. I will give the Bose system to a relative.
Not exactly the cheapest solution but what the heck...I'm halfway there already.
post #8520 of 10431
The only network access is via DLNA, but many NAS contain DLNA servers. See the FAQ starting here for general background: What is DLNA?
USB is more popular here than eSATA because it allows hot-plugging new devices, where eSATA requires a player reboot. USB 2 is fast enough for current purposes.
-Bill
