AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-95 Owner's Thread
Official OPPO BDP-95 Owner's Thread - Page 326
post #9751 of 10430
After all the hype on all a/v forums I decided to buy the Oppo bd95. Got it delivered from Oppo direct and hooked it up to my system(Denon 4311)
1. Kept freezing up when streaming on all devices. internet, usb stick drive,ext. hard drive and my own network. Also just using the remote around the menu.
2. green fuzzy screen that Oppo says is a handshake issue which I've never experienced on any other piece of equipment(samsung bd6700, ps3, directv hd box)
3 Played SACD Pink Floyd Dark side of the moon the first day and now says unknown disc also another sacd says the same.
4. Would not play WAV music files the first day, just kept scrolling through until it stoped. Now today it plays them.
5. Music CD played about 40 minutes and just ejected on it's own. Disc was hotter than hell.. Oppo says "The discs will be warm to hot depending on how long the disc has been played and how fast the discs are spinning in order for the data to be played back. CDs will spin faster than DVD, for example, so it is expected that CD media will eject at a higher temperature than DVD."
So does that mean it should eject all on it's own when it reaches a certain temp???
This is what they want me to do now, "Disconnect the BDP-95 from the power source for no less then an hour. Press and hold the POWER button on the front panel for 5 seconds. Release.
Reconnect the power to the player directly to your walled power outlet, bypassing any switch or power conditioner.
Ensure that the back switch on the power supply is set to 115V and not 230V.
Download and install the 74-0908B Firmware (https://www.oppodigital.com/blu-ray-bdp-93/bdp9x-firmware-74-0908B.aspx).
Perform a Reset Factory Defaults (Device Setup), Erase BD-Video Data (Device Setup->Persistent Storage) and disable BD-Live (Network Setup).
Use a lens cleaning kit to ensure that there are no obstructions on the lens which will cause laser pickup error. Please try running the lens cleaning solution several times, as one or two attempts may not be enough to remove some obstructions.
Try playback again.
If your SACDs still fail to load, then your player will need to be repaired. Under this condition please respond with your shipping and contact information so we may issue a return shipping label and authorization for the repair of your player.
I'll try this and let you know the results.
post #9752 of 10430
Well i did everything Oppo asked and so far everything is good. This is the beta firmware they had me download.
post #9753 of 10430
I'm relieved it worked for you but i believe that if you had also re-installed the released FW, it would have worked just fine like the beta for there's nothing about the beta that would resolve the problems you listed above. Either way, its great that your player is working fine smile.gif.
post #9754 of 10430
This may be a daft question but is it possible to connect a Roku box to the 95. I know that the new players will take the Roku stick, but all this streaming business got me interested and i dont want to junk my 95 just yet as had it less than a year? I have looked at the Roku box and it seems like you can only connect direct to TV or amp via hdmi, i see it has USB but is this only for input rather than output?
Thanks for your help.
post #9755 of 10430
^ The Roku Streaming Stick will only work with the 103/105 players.
--Bob
post #9756 of 10430
"I'm relieved it worked for you but i believe that if you had also re-installed the released FW, it would have worked just fine like the beta for there's nothing about the beta that would resolve the problems you listed above. Either way, its great that your player is working fine ."
I did a factory reset and re- installed the firmware update and still had the issues. They were resolved when I did the process they told me to do, I don't know what fixed the issues but Oppo said that it was probably a combo of both the beta FW and the process they had me do.
Yes I'm EXTREMELY happy that it worked, but a little dissapointed that a $1,000.00 machine had to go through all those issues. My $220.00 BRP worked perfectly and still does. I'll bet money that with the same equipment and movie you probably wouldn't be able to tell the 2 machines apart for movie viewing.
post #9757 of 10430
For Blu-ray you really would not see any tangible difference between the two players. You bought the BDP-95 for its increased de-interlacing and scaling capabilities which are most easily seen with standard DVD media, and for its more accurate analog audio performance.
post #9758 of 10430
Correct!smile.gif Has anyone else had any of these issues with their bd95? Or was I just the lucky one:rolleyes:
post #9759 of 10430
It sounds like you just had some random one-off errors and your player is in perfect working condition. Random errors will occur with a sophisticated piece of electronics such as the BDP-103
post #9760 of 10430
I just got the BDP-95 this afternoon. So far the sound is totally an upgrade from the BDP-83. Going thru some premium material to really see the difference in sound quality. Now contemplating what I plan on doing with the BDP-83, will probably sell it soon. Let me go and play with my new toy some more. Later!
post #9761 of 10430
I have yet to find an SACD the 95 will not play. However, I have found SACDs that the Oppo will play without error that my Denon 2900 would not.
I hope you have the same experience I have had with the 95 from now on.
post #9762 of 10430
AMEN to that! lol
post #9763 of 10430
Originally Posted by wmcclain View Post
Correct. You actually have a choice under TV System in Setup:
  • NTSC: converts PAL to NTSC
  • PAL: converts NTSC to PAL
  • Multi: does not alter the signal frame rate, etc.
This matters only for PAL DVDs or the rare 50hz content on BR imports.
-Bill
It works perfectly. I bought 'Kidnapped' a miniseries from the 70s only shown once in this country. David McCallum (aka Duckie) plays Alan Breck Stewart, the Scottish Rebel. Always one of my favorites.
The only real hang up is the player recognizes and stretches it as 16x9, but everything I've read says its 4x3 so I have to go in and use the zoom function to get it back to 4x3. Otherwise it works perfectly.
post #9764 of 10430
Do you have WIDE/AUTO set? That is the setting that pillarboxes 4:3 titles.
-Bill
post #9765 of 10430
Anybody know what the holdup is with the beta going official?
post #9766 of 10430
OPPO was planning to resolve additional issues and observations prior to making a new Official Firmware, but it seems that the too many hands are on deck working on the BDP-10x firmware, so it is likely that the current Beta will become Official by the end of the week.
post #9767 of 10430
This is funny! After I posted the above I went back to OPPO's site and the Beta has become official.
post #9768 of 10430
Yes, the 0908B "Public Beta" firmware has just become the 0908 "Official" firmware.
If you already have 0908B installed, there are no changes.
--Bob
post #9769 of 10430
Try playback again.
re #2
I had this issue with green static screen a number of times on mine though it only seemed certain instances would cause it to happen. Power cycling any of my devices would fix it, and even changing inputs and back if I recall. I haven't had the issue in a few FW updates though, so I am assuming it is a resolved issue. I was certainly relieved that I didn't have to warranty a $1K disc player right off the hop.
post #9770 of 10430
-Bill
No, I only have WiDE set. not auto. I'm wondering if the disc was mastered this way.
post #9771 of 10430
dupe post
post #9772 of 10430
-Bill
Quite likely. TV shows before a fairly recent date were always 4:3.
You can verify this with the player OSD. On the lower right it should show 16:9 or 4:3 for DVDs.
There is no harm in leaving the player set to WIDE/AUTO permanently. It affects only the 4:3 DVDs. (And the occasional 4:3 SD supplement on Blu-ray).
-Bill
post #9773 of 10430
-Bill
SD-DVD content -- whether 16:9 or 4:3 -- is mastered in an "in between" aspect ratio -- a matrix of square pixels which is wider than 4:3 but not as wide as 16:9. There is a data flag that comes with the video to tell which aspect ratio is intended. If flagged as 16:9 then the video is RENDERED with "non-square" pixels that are wider than they are tall -- same number of pixels, just a different shape. If flagged as 4:3 then the video is rendered with pixels that are taller than they are wide -- again, same number of pixels, just a different shape. This use of "non-square pixels" in the rendering process is how SD-DVD survived as a transitional format between traditional 4:3 TVs and the newer, wide screen HDTVs.
16:9 = 1.778. 4:3 = 1.333. For NTSC SD-DVD, what's on disc is always and only 720x480 pixels. 720:480 = 1.500, right in between.
For 16:9 content displayed on a 16:9 screen that means nothing extra needs to be done. The normal rendering process of using horizontally wider pixels is sufficient. The matrix of pixels making up each frame of the 16:9 content will just fill the 16:9 screen when rendered that way.
For 4:3 content displayed on a 16:9 screen, the rendering using tall pixels means that the image has the proper 4:3 shape -- filling the 16:9 screen top to bottom -- but the image is not wide enough to fill the screen side to side. That means that padding is needed on either side -- called pillar box bars.
In the OPPO, 16:9 Wide/Auto will detect the flag that says the SD content stream is 4:3 and will generate the necessary pillar box bars as part of upscaling, e.g., to 1080p output.
16:9 Wide on the other hand, does nothing. Since no pillar box bars are generated, that means the 4:3 source content gets rendered with those wide pixels anyway, since of course something has to go in every pixel of the 16:9 output. And so the image looks stretched horizontally.
Now you might very well channel the power-mad Yzma from "The Emperor's New Groove", and ask, "Why did we ever install that lever in the first place?"
The reason is two-fold. First some people don't like pillar box bars. They would rather see their 4:3 content stretched to fill their 16:9 display, even though that makes everything look fat (circles look like wide ovals). The alternative would be to "Zoom" in on the image so that it fills the screen left to right, but that means you lose a significant portion of the image offscreen on the top and bottom.
Most purists would recommend you watch your 4:3 shows in 4:3 -- the way they were intended to be seen -- but if you prefer otherwise, then just tell most purists to get stuffed. It's your TV.
(Even purists would suggest you limit use of black pillar box bars during the early "burn in" of a new TV to help avoid "image retention".)
The OTHER reason is for folks who prefer to have their upscaling done external to the player.
You see the addition of the pillar box bars should ONLY be done as part of upscaling the SD content to HD. Why? Because the SD video -- whether 16:9 or 4:3 -- is still always and only 720 pixels wide on each line (for NTSC video)! Same number of pixels, just a different, non-square shape.
So if you set the player to output 480i or 480p -- intending to let your AVR or TV upscale that to 1080p for you -- you should *NOT EVER* set the OPPO to ALSO add the pillar box bars! That's because those black pillar box bars will chew up a significant number of the 720 pixels across each line. The 720 pixels of the original 4:3 content will have to reside in the fewer than 720 pixels left in the middle of each line.
Which means you have just discarded a significant amount of horizontal resolution!
When the pillar box bars are added as part of upscaling, they still take up pixels of course. But what they take up are *HD* pixels. A 1080p image has 1920 pixels across each line. That means that even with the pillar box bars in place there are still plenty of pixels left in the middle to hold all the information content represented by the original 720 pixel lines of the SD image.
SO, if you are going to use 480i or 480p output from the OPPO, then set 16:9 Wide -- not Wide/Auto. And then ALSO set your AVR or TV (whichever is doing the upscaling for you) to add the pillar box bars itself.
But if you are like most folks and are using 1080p output from the OPPO, you can leave 16:9 Wide/Auto set all the time (applause from the purists!). For HD content, and for 16:9 SD content, that will do nothing. For 4:3 SD content it will generate the necessary pillar box bars as part of the upscaling -- i.e., no loss of horizontal resolution.
What of HD content, then? Well HD content uses "square pixels". 16:9 = 1.778, and the 1920x1080 or 1280x720 HD images on disc are ALSO 1.778.
So no need for a flag, and no need for generation of pillar box bars. But wait! What about the 4:3 stuff I see in Blu-ray discs of old movies? Well that's still, really, 16:9 content *ON DISC*! The studios have already INCLUDED the pillar box bars, embedded in the content, when they authored the disc. So again, 16:9 Wide vs Wide/Auto makes no differences. The player always sees HD video input as 16:9.
The same thing happens if you view a "wider than widescreen" (e.g., Cinemascope) movie. Those black bars that you see top and bottom are already embedded in the content coming off the disc. The OPPO is not creating them.
NOTE: For folks playing media files off hard discs or the network, 16:9 Wide/Auto will ALSO provide letter-box bars top and bottom if the aspect ratio of your media file happens to be wider than 16:9. So if you play a media file and think it has been incorrectly stretched vertically, that's likely because you don't have 16:9 Wide/Auto set.
--Bob
post #9774 of 10430
Nice explanation, Bob. Thanks (from a purest tongue.gif ).
post #9775 of 10430
Originally Posted by underling View Post
re #2
SO far no more green screen/handshake issues thank God. I'm very happy that i didn't have to buy extra warranty for a 1K machine as well.
post #9776 of 10430
Really depressing news tonight from Oppo with a factory replacement of a 95 I bought in May.
They indicated that this machine does not have the horsepower to downmix a phantom centre channel and leave the SBL and SBR alone. Essentially I run my system in a 6.1 config and the best this player can muster is 4.1.
Honestly, I am very surprised by this, given all the accolades it received, and the fact that my previous player could do this. Very disappointing.
post #9777 of 10430
-Bill
Checked the OSD, it is 4:3 as I thought. Thanks for the help.
post #9778 of 10430
--Bob
Thanks Bob, definitely a thorough explanation. I'll have to digest this, but in summary I change my setting from wide to wide/auto and all will be good!! I am a purest. I don't like 4:3 stretched to 16:9. Maybe if i had a plasma I'd get used to that, but with the LCD I always watch 4:3 content in 4:3.
post #9779 of 10430
Hi
I am considering pairing a Cambridge Azur 851a amplifier with my Oppo 95. I feel it would be a good pairing for maximizing the 2 channel capabilities of the Oppo. My main concern is my ability to upgrade to multi channel in future. I have noticed reading through the Cambridge instructions that av bypass mode is available. This way you can connect the 2 channel source direct to the Cambridge and then a multi channel source to a av receiver and connect the av receiver to the Cambridge via fixed level inputs so that the 2 front channels of a 5.1 arrangement are driven by the Cambridge with the remaining channels driven by the AV amp.. The diagram in the Cambridge instructions show two different sources a 2 channel source direct to the Cambridge and multi channel source to the AV amp. Could this arrangement be used with the Oppo employed as both the 2 channel source directly connected to the Cambridge via xlr and as a multi channel source into the AV amp via the surround analogs or HDMI and onto the Cambridge through the fixed level input? If possible i could then use the oppo as 2 channel direct via Cambridge input and then switch to fixed level input to use for surround listening through the AV amp and Cambridge.
Thanks in advance for your assistance.
post #9780 of 10430
Originally Posted by leev View Post
Hi
I'm not sure this is directly applicable to your question. My Cary Cinema 11a processor has two selections for analog, stereo via XLR or 7.1 via RCA. The XLR outputs from the Oppo 95 is connected to the XLR inputs of the Cary and 8 RCA cables are connected from the Oppo to the Cary. The Cary is set to bypass mode so it doesn't digitize the inputs. A press of a button on the Cary remote selects between stereo and 7.1.
I resisted the RCA bundle for a time, and used HDMI, but a bug in the Cary did not permit bass management with SACDs even with PCM. So I went analog to get bass management that could activate the subs. Now I have LR speakers that don't need to be supplemented by the subs, so I use DSD output from SACDs. Any discs with .1 can activate the subs.
db
