Hey all, I've been searching my brains out looking for a solution: here is what I am looking for:
I have just built an HTPC with an Asrock H55MUSB3 R2.0 MATX MB. I am running W7 and I would like to control it (turn on from S3, navigate movies, MCE) with my Harmony One remote. I don't care about PC functions or surfing the web as I do maintenance via RDP and hate surfing the web on the TV.
The Asrock MB has an IR header that I would like to use if possible (I only need the RX function, I am not controlling anything else with the HTPC):
What I would like to end up with is an 1/8" jack on the back of the PC to connect to my IR distribution hub. I could go with an internal reciever and IR emitter, but if I can avoid this it would be cleaner.
If that is not feasible, an internal USB reciver would be fine. I don't want anything that needs a 3.5" bay or the like; I would be modding the case with (hopefully) a small hole for the reciever.
I guess I could take apart an external reciever as a last resort.
If I have to build something from scratch that would be fine too.
If anybody has any insight/experience/links they would be able to share I would really appreciate it!
I didn't see this at all in my searching... (J/K)
