AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › The Official Silver Fire V.2 Thread.
The Official Silver Fire V.2 Thread. - Page 14
post #391 of 1129
Originally Posted by ERuiz View Post
If possible, clean the sprayer after EVERY coat. I know its tedious but at least you will ensure that the sprayer will spray evenly and consistently.
Good tip.
Originally Posted by premiertrussman View Post
Whoops i jumped to conclusions :-P.
What do the materials generally run for a batch of SF?
About $85 total for my two 120" lengths of Spandex. I bought locally though. You can get it online cheaper.
I wouldn't recommend Spandex unless you're look acoustically transparent cloth. The rubber side of Blackout Cloth is a superior paint surface, IMO. And less expensive with the correct source.
post #392 of 1129
Btw, the white cotton/spandex blend is an absolute fracking fail. Boatload of small-time cash wasted on this project so far.
The paint blend itself shows promise though.
post #393 of 1129
I was also getting mixed results with both sides of BOC and spray painting. I finally went with drywall and the finish is as smooth as a 90 year old's gums.
post #394 of 1129
Yuck. We like to use the terminology; "Baby Butt Smooth" yar'bouts.
Besides...haven't ya'all ever heard 'bout Dentures?
post #395 of 1129
Not to be a pest, but does anybody have tips for mixing? Doing it this weekend, and don't want to screw it up...
Steve
post #396 of 1129
I'm having some trouble spraying the HG mix. It is not as dark in color as all of the other SF mixes and so I'm having a tough time seeing where I've sprayed. This obviously makes it difficult to get a 60% overlap consistently. Any suggestions?
post #397 of 1129
determine what the size of your vertical spray fan is at the distance your are shooting from...
for me that would be approx 16" spray distance... so if my verticle spray fan is 8"... then i would drop down only about 5" to get my 60% overlap.
post #398 of 1129
Steve
Hi jonesi,
Sorry we kept'cha hangin'
A. Mix the Reflective Base and the Viscosity Base seperately
B. Mix the Colorants using either a large Syringe to draw up precise amounts to dispense directly into 75% of the recommended water inside a Glass container, or by simply squeezing out the needed amount into a Shot-Glass sized measuring cup.
Note: If you have a small Digital Measuring scale, place the Shot-Glass measuring container on it, Zero it out, then dispense the selected Tint "slowly" up to the prescribed measured line. Note the "weight" and use that as a guidline for everything else, percentage-wise.
Another sure fire method is to simply dispense an entire 2 oz tube of any particular Tint into a zeroed out container, note the weight the two onces amounts to, then simply divide downward to match the amounts needed for each of the 4 colorants.
Myself, I just use entire tube by multiplying the smaller amounts out until I reach more easily obtainable amounts. The "Weight" method is extremely accurate, and it's nice to be able to use your remaining portion of water to rinse out the container your using.
The real key is to be a precise as possible in the measuring of the Colorant, as it's degree of "Neutrality" is wholly dependent upon getting the proportions as close to perfect as possible to achieve a pure, dark neutral Gray, which itself should resemble a ultra dark shade of Dirty Motor Oil...and when rinsed off a utensil under a light stream of water into a white basin will show a distinct, pure Gray color. If it looks Brown, Reddish, Greenish, or Blue-Purplish....post up again immediately for the needed corrective action. That action might simply involve going ahead and mixing it into the combined Reflective Base & Viscosity Base, and then correctly the obvious Color Shift. Trying to correct the Colorant itself is extremely difficult and not advisable.
So OK then....you got your Reflective / Viscosity bases ready, and your Colorant is bang on correct. Using the Squirrel Cage Mixing Tool on low speed, mix the Colorant into the Viscosity Base slowly, and do so only until you see the majority of it blended well.
The pour the Viscosity Mix into the Reflective Mix and slowly blend them together. DO NOT USE A HIGH SPEED TO MIX! This will "whip" the paint, creating air bubbles, and you want to avoid that.
At this point, before you add any additional water, you lift the Mixing tool out of the paint and note how smoothly and fast the paint runs off the Tool. It should not "slide or ooze" but actually "drain off" and the Turbine vanes on the mixer should "pop" open in under 20 seconds. If not, add water in additional 2 oz increments until it (mix) does exactly that.
Now your ready to strain the paint mix through a 1 Gallon "Nylon Sock-Style" Strainer into a "CLEAN" 1 gallon paint can.
After that, should you find upon trying to paint that the mix still does not flow freely and produce at least a 12" tall vertical pattern, add additional water in 1 once increments until it does.
Tips:
Rinse off the Mixing tool "Immediately" after using it.
Disassemble and rinse out the Gun and Tip pieces, It only takes a couple minutes and assures that the Gun has a clear, free-flowing action every time. The Wagner CS (Regular & Double Duty) being integrated Turbine/Spray Head guns, heat up just enough that such heat can bake the paint onto the Plastic components, therein restricting or plugging up the parts.
If there are any other lingering doubts about how to do the spraying, times between coats, types of coats, etc....don't rush in to keep going on a hope, or make any guesses. Haul up and post, or contact me (check PM) and getter dun right the first time.
It's more fun and infinitely more satisfying to do so....believe me!
post #399 of 1129
Ok so the only thing I don't understand is the using the entire tube by multiplying out until you reach more obtainable amounts....how does that work then? Do I mix it all together based on the color I want, then add a lot more of the other colors in proportion to each other...then use a certain number of ounces in the final mix? Not sure I follow.
Materials I am going to buy to mix:
Squirrel Cage Mixer
Measuring Shot Glass
Three empty paint cans
Big measuring cup (1x 2qt)
Small digital scale
Lots of distilled water for rinsing and my Wagner DD
And a nylon paint strainer (from Lowe's? don't know where to buy)
Doens't look too tough to mix...but I will be extra careful.
Anything else recommended?
Steve
post #400 of 1129
The original formula makes approx 4.25 oz. of colorant.
If you opt to use larger amounts of each Tint, measuring becomes easier, and you can always share the remaining excess with other members by posting up it's availability.
Here's some help: (ounces are US-Fluid)
30ml - Liquitex Basics - Napthol Crimson Red (= 1 ounce / 120ml = 4 oz. )
15ml - Liquitex Basics - Phthalocyanine Green (= 0.5 ounce / 60ml = 2 oz. )
10ml - Liquitex Basics - UltraMarine Blue (= 0.3 ounce / 40ml = 1.35 0z. )
5ml - Liquitex Basics - Cadmium Yellow - Deep Hue (= 0.15 ounce / 20ml = 0.675 oz )
240 ml Water = 8 oz. (well...close enough)
8 oz Water
8 oz Colorant
= 16 oz Total colorant
Ya got plenty of water in the Mix above, but the wagner rinses out under normal tap water
There, or at Home Depot They come in a package of 2 for $1.99
They rinse out super easy (rinse backwards) if you do it immediately after you strain.
If the paint's viscosity is correct, the paint should rise up and pool slightly in the Sock Filter's "cupped depression" you make at the top of the can...under a slow but steady pour....but when you stop pouring, the paint should receed fairly quickly.
That is the best way to judge the correct viscosity....NEVER depend on or use the little Black Viscosity Funnel that comes with the Wagner.
Doesn't look too tough to mix...but I will be extra careful.
I'll hold ya to that......
Steve
Beer....
....make sure that the top/Bottom/Side edges have a "Run-Out" area that does not drop further than the thickness of the actual material your spraying onto. (...if it's a wall, disregard the above but rape up some Border material that will plainly show your paint line as you run off/out of the screen area. This is a great help at judging how much paint is going on, and how effectively you are maintaining your Row drop percentage. (60% Row overlap / 40% drop distance)
Practice......w/beer in hand.
Drink conspicuous amounts of beer before you get started to allay any nervous condition, and maintain administering such lubrication throughout the painting process.
I really do not have much else to go on about your situation so that's about all I can offer now.
Except drink good beer. Lousy beer will result in a totally failed effort.
post #401 of 1129
Hi, need some help with screen drywall or wilisonart laminate with hd 70. sliverfire mixture for these choices. Thanks in advance
post #402 of 1129
OK, thanks.
post #403 of 1129
Hello everyone! I have been thinking about plunging into the projector game. I presently have a 54 inch panasonic plasma, but want to go bigger. I was wondering if I could get some good info here. I currently reside in an apartment with 8 foot ceilings, 16' deep, and 12' wide. I would say that my room is ambient due to the cream colored walls and tan drapes, but at night it is very dark in here. The 12' wide viewing area has wood paneling on it, so it may or may not help stunt reflections of light. I am considering trying to make a silver fire greyscreen 120" 16x9. I really like cinemascope, but I have a PS3, 360, and Mac Mini, and feel that 16x9 is the most versatile.
For the projector I have been reading about the Epson 8350 and think that may be the best value. I also have 7.1 surround, so jockeying everything around will be interesting.
In terms of materials I like the idea of canvas, and getting the wagner spray can. I'm thinking that electric screen is probably best, but the idea of making my own screen and saving money is really exciting and is the possibility of building something that I can say I had a part of.
Anyways, I wanted to hear what you guys think, and any advise would be appreciated. Thanks.
post #404 of 1129
Originally Posted by CHUCKCHILLOUT View Post
Hello everyone!
Hi! Welcome aboard.
That's because it's night time...and there is no light. Turn on a PJ and deliver a 120" light source and watch how "lightened up" that room will get.
Good thinking, that.
For the projector I have been reading about the Epson 8350 and think that may be the best value. I also have 7.1 surround, so jockeying everything around will be interesting. [/quote]
The 8350 is a great choice...perhaps the best PJ ever for those wanting 1080p on a budget yet not wanting to compromise. However you might want to consider the 8700 because your situation NEEDS all the contrast help it can get.
Ditch the Canvass idea. Consider instead 5' x 10' Sintra Board in `1/4" thickness. It's virtually self supporting, a very smooth white surface that needs no priming, and accepts the sprayed on paint like a dream.
Well there ya go....do some thinin' and come back with your next post and let use know what direction you decide to head in.
post #405 of 1129
Edit....
Right the first time,
Right everytime,
Continiously Improve...
Should be the thought in planning a Home Theater..
post #406 of 1129
hmmm... seems to be a singular opinion by you alone. you don't belong on diy nor does your post.
Really because i thought we were allowed to post our opinions.
Because I See others from DIY Corre posting there views in Non DIY Screen threads Even Screen shots of there views..
So why is it okay the one way but not the other..
Isnt that a double standard...?
Edit...
post #407 of 1129
you are on DIY as a BD dealer promoting manfacturer's screens and especially have no reason posting on this thread as such.
post #408 of 1129
Actually You Stand Misinformed,,,,
I thought all where allowed to share there opinions so i dont want to break any rules so i will edit my post ...
post #409 of 1129
Originally Posted by fraisa View Post
In a recent Home Theater Mag Screen it article about picking out a screen for a Hometheater room,
this DIY Screen paint or any is not even mentioned...!
Maybe because it was an article for PICKING OUT A SCREEN and not building one yourself?
Regardless, I don't see anything wrong with buying a mfg screen if that's what you want, just as I don't see anything wrong with building one yourself.
Building your own screen is not rocket science. But if someone doesn't have the skills, time or motivation to build one and prefers to buy a mfg screen, great. But to say this is a waste of time for just saving a buck and ending up with a second grade result, just shows me you have no clue what you are talking about. I will just take your post as a sorry attempt at trolling.
post #410 of 1129
Its an opinion that others have but again i have edited my post..
and you are right about that there is nothing wrong with wanting to build your own screen....
post #411 of 1129
Don't just "Edit"....hit the "Delete" boutton. Nothing you posted makes any sense, nor hold any weight considering the years of satisfied DIY'ers, their combined successes, and the many, MANY dedicated Theaters, Theater far more involved and extensively designed than yours, that spor excep0tional DIY screens.
You have no experience at all in DIY screenmaking...even your thread on this Forum constitutes a silly premise....that a Taupe painted wall is sufficent to use for a screen. It really just shows your effort for what it is, your vain attempt to try to belittle all other DIY scrren efforts by advocating a off color paint as being "JUST AS GOOD AS..."
As pb said, posts such as yours, coming from the source they do, espousing the opininons they show, are simply inappropriate and serving your own agenda.
post #412 of 1129
This reaction has just proved alot...
ANd i have edited my post
post #413 of 1129
At least you got that right. But will it stick? Almost assuredly not.
post #414 of 1129
This thread took an interesting turn.
Anyway.
So I'm about 99.9% sure I'm going to get an HC4000 and go with a SF v2 2.0 screen at 102" . I have the flexibility with this pj to put it where I want on the ceiling so I can mount it anywhere from 10' 3" to 15' 4" from the screen. What would be the preferred distance?
I'm looking for the best black levels I can get, and in the first thread I got most of my questions answered, but for a 92" screen. Would the SF v2 2.0 (is that the same as HG or no?) still be the recommended mix for movies in complete darkness with some ambient viewing for TV and video games? Black levels while in "bat cave" mode would be more important than anything.
Also, I was going to use Thrifty white for my 92" screen, but now I can't because I haven't been able to find anything locally other than 4'x8'. 5'x10' will work, but I don't know where to get something that will be light and not too expensive. Recommendations?
EDIT: Found a sintra dealer in Dallas.
http://www.sabicpolymershapes.com/po...Home/home.html
post #415 of 1129
bump.
pb_maxxx...mm...anyone?
I've got only a few weeks to get this stuff together. Please help a guy out. (not that you guys haven't already).
Sorry, I get impatient.
post #416 of 1129
shortest throw plus a few inches... so mount it at 10'8" - 11'.
go with SF V2 3.0
post #417 of 1129
go with SF V2 3.0
Thank you sir.
post #418 of 1129
I am brand new to posting but have been following along in this forum for some time. I am looking for a Silver Fire V.2 color reccomendation.
I just mounted my HD180 with a throw distance of 10'-6" and am going for a screen size of 92". My walls are painted dark chocolate, ceiling is painted a metallic copper color. Viewing distance will be 12', ceiling is 7.5 to 8 feet tall, side walls are 8'-6" from the center of the screen to the left and 6'-8" to the right.
The room can be almost completely light controlled with a blackout curtain in the back but the room is adjacent (on the rear) to a rec room, bar, etc. so when we have people over to watch the game, etc. we will want the screen to perform well with some ambient light. There are north facing windows in the back but they are about 12' from the back row of seating.
I think I gave you everything you need for a reccomendation but if not, please let me know.
I know everyone loves pictures (at least I know I do) so I will post some here soon.
J
post #419 of 1129
I think I gave you everything you need for a recommendation but if not, please let me know.
J
SF v.2 3.0 And you should be able to run the 180 on low lamp to achieve even better black levels.
Try to mount the top of the screen at least 16" down from the ceiling, to both allow for your PJs mounting considerations (see below**) as well as to reduce the penchant for any reflections from off that metallic copper ceiling.
**Be advised that the 180 will have a 7.2" lens Offset so when you mount it inverted, your drop from the ceiling, including the PJ's body height and mount assembly/Ceiling plate, must be exactly 7.2" less from "Lens center" to the top of the Screen itself.
........now I have to ask ya....how / why does the ceiling height vary from 7.5' to 8'? Where does this variance occur? Anywhere in line with the Screen wall and the 10' 6" throw location?
post #420 of 1129
Thanks MM!!
I'm probably 1 week or 2 from starting my screen but I am going to give Thrifty White Hardboard a try. Just now finishing my AV cabinet, Onkyo TX-NR609 7.2 came yesterday from Amazon, picked up my Harmon Kardon speakers from DirectBuy today.
I will take note of the 7.2" offset.
The projector hangs over a 4" deck for the second row seating plus the ceiling has a 2.5" architectural recess over the seating area.
Thanks again...hopefully I remember to take some pics tonight for you all to have a look tomorrow.
J
  Back to Forum: DIY Screen Section
