Here is my TVFool channel listing:
http://www.tvfool.com/?option=com_wr...3cf4966e0dafd3
I am only wanting to get the prime channels that are in green. Weekest signal strength is -41.2dBM
ABC, CBS, NBC, Fox, PBS is all at 85* to 92* azimuth.
CW is at 316* Azimuth
The rest is garbage.
I can do outdoor or attic, but it looks like I should NOT have an issue with an attic antenna.
Here are my choices, and my main concern is being able to get the CW channel with it's azimuth being about 50 degree off from the rest.
ClearStream2
http://www.amazon.com/gp/product/B00...A1GO776JZJGBGT
Antennas Direct DB8 Multidirectional HDTV Antenna
http://www.amazon.com/Antennas-Direc...6600890&sr=1-1
Antennacraft® Colorstar C490 HDTV/VHF/UHF/FM Antenna
http://www.radioshack.com/product/in...ductId=3767303
Would either of these require boosting if being split and sent to two receivers?
THANKS!
ClearStream2
THANKS!
