AVS › AVS Forum › Other Areas of Interest › Car Audio, Video, and Nav › Any amp suggestions for a DVC 6ohm?
post #1 of 4
Hey, I just had my friend buy a JBL GTi 15"
DVC 6ohm (x2)
800 watt RMS
5000 watt max
I'm looking to put around 700-800 quality watts into it.
But.. we are having problems looking for an amp. I know if I wire the sub in series it will be a 12ohm load, and in parallel it would be a 3ohm load. Am I correct with these calculations?
Would it be a problem to / How would i go about: push(ing) a 4 ohm amp at 3ohms? What would be any pros or cons to this situation?
post #2 of 4
http://cgi.ebay.com/JBL-1500-Watt-Mo...item230de45c9a
http://cgi.ebay.com/JBL-2200-Watt-Pa...item5adecedc86
The above2 amps are going to do what you want.The second one is a true monster read up on the BPX line.
Otherwise, find a class D amp that putts out the wattage you want at a 4 ohm load. Wire the coils in parallel for the 3 ohm load and call it a day. Make sure you use a mono (single channel) amp.
your understanding of the different wiring schemes is spot on.
Great sub by the way!!
post #3 of 4
thanks! would a kicker zx1500.1 be suitable? can get a deal right now on it
post #4 of 4
that amp should work fine.
  Back to Forum: Car Audio, Video, and Nav
