I haven't seen here detailed comparison of LED-Hybrid Casio projector and projector with mercury lamp, in this case BenQ MX710.
I don't want to post here too much, so here's the conclusion of comparison:
"9 (pluses) for BenQ and 6 (pluses) for Casio, so it depends on user needs. If you like perfect looking, easilly portable projector, don't like to change lamp, noise doesn't bother you - Casio is way to go. On the other hand, if you need sharper image, higher contrast ratio, silent operation, ability to play 3D games over PC - BenQ is your choise."
Full comparison here (https://spreadsheets.google.com/pub?...en&output=html), including total cost of ownership comparison, DMD chip size comparison and so on.
So what are most important specifications of projectors for you? Weight/size, noise, lifespan, image quality, or else?
