Does anyone know where I can pick up the microsoft brand toslink optical rca audio adapter. On bestbuy.com they list it included with the hdmi cable, but that is not correct. It is only the hdmi cable.
Hdmi Cable
I was going to get it because it said it included it, but nope does not. False advertisement in bold. I went there yesterday had them open the box and only the hdmi cable.
Prepare for enhanced audio enjoyment. This HDMI Cable provides you with separate audio and video connections via the included audio adapter. The audio adapter allows HDMI video to be routed to your HDTV, while the audio is routed separately to your home speaker system.
Without the audio adapter, the video and audio signals would both be carried by the HDMI cable. That would force users without a costly HDMI receiver to listen to their Xbox 360 game and movie audio via their TV speakers. That is not the case with the included adapter you'll be able to hear every blast, word, music note and sound effect through your home entertainment system speakers for audio that really packs a punch.
Hdmi Cable
