AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › Battlefield 3
Battlefield 3 - Page 85
post #2521 of 14542
Thanks for he cut and past! The hi res photo wont show for some reason. I cannot wait!
post #2522 of 14542
Originally Posted by Budracin8 View Post
IGN article says BF3 is SD without installing high res disc.
http://xbox360.ign.com/articles/121/1210229p1.html
I don't see where it says it's SD (meaning running at a lower resolution). That absolutely would not make sense (not to mention be against MS rules). He's just throwing the terms SD and HD around a little too casually.
The only difference is going to be the texture resolution. He's a little disingenuous when he acts like no one else is doing texture streaming (everyone does nowadays). But this allows them to double their storage space, and guarantee they're streaming off a faster HDD. It's a clever way of skirting around a few issues - space, speed and disc swaps. It's screws only the minority who dont have HDDs. I wouldn't be surprised if it becomes the norm going forward.
post #2523 of 14542
Agreed. He was trying to use it as an allegory, but it was the wrong allegory to choose (as some people will obviously misunderstand it as literal).
He should have called the streaming textures something like, say, an "afterburner". (Tho, now that I think about it, that still might be too "technical" of an allegory. If people don't know what an afterburner does, that won't mean much...)
post #2524 of 14542
If you aren't streaming, aren't the textures running at a lower resolution, ie the terms standard definition and high defintion aren't all that inaccurate?
post #2525 of 14542
Textures are always streaming. Even with lower res textures Im sure theyre still bottlenecked by the available Vram. It's just a question of how high a resolution texture they have at hand to stream in.
Standard def and high def have very specific meanings. Texture resolution has zero to do with it. You'll still probably see some benefit from the high res textures even if you're running at SD resolution. it's just muddying the water to use those terms.
The thing is that they're trying to make it sound like they're doing something special that no one else has. That BF3 is going to have the best textures EVARR because they're including a special disc. The reality is that there is no way they could squeeze the game onto a single DVD. Their choice was either to cut maps out, reuse textures more often, force disc swaps depending on the map or mode, or do what they're doing and leave people without a HDD with an inferior version.
They made the right choice IMO, but that's cause I have a HDD. Make no mistake, the disc only version is going to have some really blurry textures up close. I'm 99% certain the beta was using the high res textures.
If you don't have a HDD, you'll almost certainly be able to use a $10 8GB USB stick for this purpose as well.
post #2526 of 14542
I have a 20g HDD that's pretty full. Can anyone recommend a good OTC USB stick? Or does it even matter?
post #2527 of 14542
The patriot xporters are pretty good. Especially the rage XT ones (what I use to install games on).
It probably won't matter all that much. You might see a little more texture pop-in with a slower stick.
post #2528 of 14542
Also, GameStop is running a sale on used 360 HDDs.
20Gb - 9.99
60gb - 19.99
120gb - 24.99
You're not going to want to play this game without the texture pack. If you don't have a HDD now is the time.
post #2529 of 14542
Would we get better performance from using a USB drive vs a hard drive?
post #2530 of 14542
I thought you couldn't install games to a USB stick, that they were strictly for game saves or DLC. If you've actually done it before then obviously I'm wrong, but can you confirm that?
Edit: A little Googling says that you can install to a stick, but not to a mechanical USB drive. That must be where I was getting my wires crossed.
post #2531 of 14542
I do it all the time. Slightly faster than a HDD in most cases - thats why I do it.
I've got two of the fastest 16GB sticks I could find dedicated to the purpose.
post #2532 of 14542
Yep, I edited above. Probably right before you posted.
post #2533 of 14542
Yes, you can. (this article is from last spring so the performance data is probably outdated, however it does show that you can install games to a flash drive)
http://www.examiner.com/video-game-n...sb-flash-drive
post #2534 of 14542
For the texture dump, I seriously doubt it. For speeding up game loading time, almost certainly. (but only by a second or two)
Given the choice, install the game to USB and the texture disc to the HDD.
post #2535 of 14542
You can install games to anything over USB - even HDDs or SSDs in an enclosure. You're limited to a 16GB partition per device, and you're bottlenecked by the USB bus - so forget about any fantasies of super fast loads on an SSD.
post #2536 of 14542
"The thing with the 360 is that you need to be able to give consumers a game where you don't have to install it on a hard drive, because there are 360s without a hard drive. So we need to give you the option of installing it, rather than just demanding it. You could call it a 'standard-def' version for the 360 if you don't have a hard-drive."
I agree. SD isn't the proper term to use.
post #2537 of 14542
Any guestimate on the size of the texture disc file?
post #2538 of 14542
Any more than 7.5GB wouldn't fit on a disc. I saw the PC version is 10GB - so assuming they fill the first disc up to max, all they need is another 2.5GB.
It's probably not that clean a cut, so 3-4GB.
post #2539 of 14542
Perfect. Thanks.
post #2540 of 14542
Hold on are you saying that a SATA HD will be slower than a USB 2.0 flash drive?
post #2541 of 14542
It's been tested and confirmed (check eurogamer). The nonexistent seek time of a good flash drive usually overcomes any speed advantage the HDD might have in sequential reads or bus bandwidth.
It's too bad we can't tap straight into the SATA bus - Id strap an SSD on in a heartbeat it you could.
post #2542 of 14542
If you say so, but honestly doesn't make any logical sense so not going to waste my time...
post #2543 of 14542
It makes perfect sense if you have more than a surface understanding of it.
If you don't believe me, believe the people who do this stuff for a living.
http://www.eurogamer.net/articles/xb...factor-article
post #2544 of 14542
Even by your own admission, they are doing something else no one else has.... they are not making the other choices (sacrifices) you mention, which others games must be doing.
Though I suppose I understand your sentiment, it still seems as if they are using a "new" way to give us more. The theory itself, texture streaming, is not new, but they seem to be setting a new standard for the method -- how is done -- to maximize the quality and variety of available textures on fixed hardware.
post #2545 of 14542
Other games like rage just went with forcing a disc swap. Its not a technological advance, it's just a ballsy move to make to compromise the graphics for people without a HDD. There's plenty of good reasons not to do this.
But I'm in favor of it - one of the biggest mistakes MS made was not to include a stock HDD. If this works out and doesn't turn out to be a debacle for EA, expect a lot of games to start doing this.
post #2546 of 14542
Does it have anything to do with the speed of the DVD drive not being able to stream the textures they want fast enough?
post #2547 of 14542
Not really. The main problem is storage space on disc. A faster drive is always better to completely prevent pop in, but every other game manages it off a dvd just fine.
post #2548 of 14542
Campaign or going straight to the MP? Once you do the MP, you always never go back to campaign.
post #2549 of 14542
MP.
I will campaign the day my interwebs goes out.
post #2550 of 14542
If the MP servers arent up this weekend, then campaign.
  Back to Forum: Xbox Area
