Originally Posted by lordxar5
Only bad thing about recon is its kind of a hang back away from action kit. Meaning you die and your goodies go away. So you either spawn as another kit or hang back a bit. Don't seem to get nearly the points as other kits because of that.
LMGs are about the same. I believe the first or second unlock is most accurate. Bipod greatly improves all of them in that dept though.
Your motion sensor stays put as long as it doesn't get blown up (usually). There is no telling with the spawn beacon though. That thing will just randomly blow up sometimes. Others I'll change kits and i'll notice after 5-10 minutes (and a few deaths) that its still up where I left it.
Still stickin by it, I'll take my SV or M95 with the acog anyday. Anything that isn't face to face you outrange and out damage big time. Even with suppression firing at you the enemy basically has to zig zag and run in circles trying to get in cover so you don't either shoot him again or HS him.
Then again its habit for me to aim high center, so i get more headshots than most others.
to each their own!Still my fav. tactic on Seine! Hold the bulding between D & B. You control D from all but the russian spawn. You control the alley and from D,A--->C, and the stairs going up from A-->C. Your motion beacon watches the building overlooking A. A stupid amount of kills, and basically the area on lock down, especially if you have a couple guys. The two just cover each other as you keep D&B capped and the rest is all killing lanes.
defender was a PITA for me to get and it is doable without boosting, C4 on the MCOM which maybe isn't much better to some people ha. I have a feeling they will change it eventually as they did in BC2 where if you get kills near the MCOM defending it counts.
