Meh I think its hard to comment on both sides until you've been in an air vehicle for many hours and can use it effectively and not just fly around.
Compare it to being in a tank, and coming up on a flag or being at an area where the enemy has a tank spawn. You are going to either A) get a teamate to take it B) Destroy it or at the minimum C) put a few shells in it to soften it up. Frankly if you don't the odds that you are going to be surprised and killed by it are pretty high. As easy as it is for you to turn your turret and fire on an unoccupied tank, its just as easy for the jet to go out for a run, hit their plane(s) on the runway and come in for a run. You aren't going to let a threat live that can end your run short. Choppers are a little different, the only time I ever spawn kill the other helo is if they have done it to me. It's just too far out of the way. If you are getting spawn killed by the enemy helo well its your fault to begin with. Its extremely easy to chase them off.
