Assault
(got 31st service star lastnight =<)
M16A3 - Acog/grip/flash suppressor
M320- On open maps
MASS- On close maps
Engineer
M4 - Kobra/laser/foregrip (2)
Support
M60 - Kobra RDS/Foregrip/Extended Mag
Recon
M39 EMR - holographic holo/laser or 8x
SV98- ACOG, straight pull
All Kit
Pistols
.44 Scoped
M93R
G18 Suppressed (3)
Vehicles
Tanks
- Thermal Camo/IR Smoke/Guided Shell,
-Reactive
Jets
-Air Radar/AA Missiles/ECM
Little Bird
-Laser Pointer/Guided Missile/ECM
Attack Chopper
-pilot-air radar/ECM/heat seekers -gunner- stealth/flares/tv missle
-Laser /ECM - stealth/flares/guided
Honestly my idea of the pistol is that the only time I want to have to use it is immediately after running out of a mag on my rifle. That's the main reason I have alway run with the G18. Its ROF is crazy and it outperforms a lot of guns in CQ. You can dump a mag in a guy coming up the stairs and still reload it before the guy comes up behind him. If I have to shoot it at range the guy is already hurt so a few small bursts and he is dead.
MPH- After flying with you last week and using the TV i just can't get into it in BF3. It should be a one shot on a tank, end of story. Not just a disable. Its awesome for killing the chopper across the map but console wise i just don't think it outweighs the performance of the guided missile.
Harp- Ya I agree on the MASS, i love that thing. I rotate between it and the M320 depending on the map. Now that frag rounds have been dulled I'll probably switch back to using the Med bag more instead of the m320.
