I have had no luck with my Pioneer PDP 507CMX... Both the front panel and remote is locked (was hooked up to an external remote via rs232).
Is there any software that can be used to access the service menu via rs232?
Just want to able to remove the lock on the IR and the front panel...
THANK YOU!
(ps: please help, so I dont just throw out a 50" pioneer)
THANK YOU!
, thus rendering the TV unusable?
