Originally Posted by stevekale
Hi guys. Slowly making my way through this entire thread - well from pg 78 anyway. I have a rather neglected CB III with 2 x Xtreme DACs and a bunch of Egglestonworks speakers (Andras that have just been upgraded to Andra IIIs - got them back last week - Andra centre and Rosas for the rear units). I want to upgrade the CB III to HD and so have been catching up on everything here (that which I understand anyway).
I have a question (to start with) that's not directly related to Theta but I thought I would ask it anyway. My BD/DVD player is an ageing Pioneer BDP 95FD (I use an even older Theta DaVid for audio CD) which could probably do with an update. Many of you seem to be fans of Oppo. I guess my perhaps rude question is what can I expect from an Oppo (versus an updated unbelievably cheap Pioneer) when it's basically reading bits and doing little processing when run alongside a CB III/CB III HD? I guess there's the video side of things. Secondly, am I right to be hanging on to using the DaVid for CD or should I switch all to the Oppo and retire the DaVid? (I don't have any SACD source material.)
Lastly, I am experiencing a little but annoying (and probably basic) issue with the 3.5 mm mono phone power triggers on the back of the CB III when connected to a Krell KAV 300i power amp (bridged centre channel amplification). The first KAV is connected to a second KAV (rear speaker amplification) via another 3.5mm mono cable. (I have a Krell FPB running the Andra IIIs.) When I take the CB III out of standby via the button on the front panel, the amps are powered on and then immediately off again. Ideas?
BTW given the range of the Andras and Rosa I am running them all on FULL and only using XOVERLR for the centre channel. (The sub is a - again ageing - REL Stentor II.) Make sense?
Thanks in advance for the advice. The knowledge gathered here is simply fantastic.
Regards
Steve
Regards
Steve
Steve, in ref to your amp switching on and off issue. This is because you have the CB3 set to pulse output on that trigger output. The Cb3 will send both pulse and constant 12V depending on the settings. Just change it to constant 12V and you should be fine.
Craig
. My post count is 1/4 of the blands
. With my mornings, usually I am going to be the early bird. I also have the luxury of a job where I do very very little. I spend about 3 hours a day on the phone with friends,the wife,and check on my elderly relatives. They are often glad to have a call, the relatives. I get to have a 6 figure salary, not a high one, doing this. Best job. I have ever had.
