Originally Posted by stevekale
OK I gave it a go via a borrowed laptop running Windows 7 Pro. I am having the same problem as SierraAlphaHotel. I tried every single COM available. Do I really have to buy a cable to upgrade this thing? It should be able to upgrade off a USB flash card!
(I only have 2x Xtreme DACs. No other DACs. I do have the older digital out card but I do not use it.)
Yup you need a good USB<>RS232 converter with a chipset / device driver that works with Win7. Just the way it is, the issue is with Win7. If you had an XP laptop you'd be good to go. You'll also need a straight-through RS232 cable. one end goes to the USB<>RS232 converter, one end goes to the CBIIIHD.
After you get the cable and converter, use the same method I did to upgrade to 4.30.
Try it and lemeknowwhatchathink...
, I do not know what is. Do you have any experience with Mac OS? Porting to Mac is going to be a big job for Jriver so I don't know when or if we might see a Linux version. Porting to Mac however will make a LInux version easier. I may send you some PM's to keep this thread from getting to off track to get some more details on what your thoughts on this are.
