AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › The official "Theta" thread
The official "Theta" thread - Page 26
post #751 of 5098
Originally Posted by Bulldogger View Post
Wait! I believe only the newer cards like the Superior II, Premium, and Xtreme can be reconfigured to handle different channels. Steve has Xtreme dacs so what he was able to do does not apply to your needs. Here's the last discussion, note Les's comments, http://www.avsforum.com/avs-vb/archi...t-1212948.html
When I sold one Xtreme last year I traded in an old superior card without knowing this. Through sheer luck it turned out to be exactly the configuration I need. I have not installed it yet, but once I sell my 2nd extreme I will use this card. I will then have one Superior II for F/L/C and a Superior 1 for Sl/Sr/Sub. I am keeping the Superior II to get better SQ on MCH once Netflix starts streaming Dolby+, but an Xtreme would be overkill for this.
post #752 of 5098
But that my point. You took out original Superior dacs, which are not reconfigurable and replaced them with cards that could be. I actually bought an old card with my CBII, Superior1, thinking I could reconfigure it. I actually shipped it in to Theta. It could not be done and the card was shipped back. I resold it.
Ah - now I get it!!!!!!!!!!!@@@@@@@@@@@@@@@@@@@
post #753 of 5098
Looks like you should sell that Digi out card. There is a guy on Audiogon with a WTB ad . Oh, I believe he has an extra metal cover, so you do not have to have an open hole there too.
post #754 of 5098
Thanks. I would prefer to sell it as a package with the volume control unit. But if this bulldogger guy on audiogon pays a reasonable price I might just go for it. I'll send him an email. The metal cover is a bonus.
post #755 of 5098
Or pull a joke on Steve. Call FedEx and have it held for pick up. He would be expecting it but it would not be delivered. You might have to hire a hit man though to kill the one Steve would send after you : ) .o
Too late. It arrived 8:45 AM today!!!!!!! So the CB3 HD is here and is not my April Fool's joke this year. The question is what is my April Fool's joke this year?
post #756 of 5098
Nice. Among the many things many are interested to find out is the output resolution of the digi out card on 96/24 HDMI sources, to be confirmed by hooking up the PWD to the digi out card....
post #757 of 5098
Great Steve! Glad you got it early.
post #758 of 5098
Well, my CB3 HD works fine using its onboard analog balanced Extreme DAC outputs.
I also have the CB3 HD working with the Six Shooter! However, still workin' on figuring how to integrate the Gen VIII Series 2 DAC for the front left and right channels in lieu of the Extreme DACs for those channels.
Just finished dinner. Back to work!!!@@@
post #759 of 5098
Congratulations Steve. Almost ready to upgrade mine. Been waiting for 1st round of bugs to be worked out.
post #760 of 5098
Steve you should be able to just plug your AES cord from the CB3 into the gen 8. Also remember to connect your volume data with a plain old patch cord. Your two Extreme cards should have been setup at theta so no need to re-program channels. Check your volume control setting in the Gen 8 other than that pretty much plug and play. Remember your L&R output will come from the Gen 8 so they must be sent to your Citadels.
Just finished dinner. Back to work!!!@@@[/quote]
post #761 of 5098
Congratulations to you, glad to hear your mostly up and running!
Maybe I over simplified the connections in my head but it seems to me it shouldn't be all that difficult to stick the Gen. VIII in between your CB IIIHD and Six-Shooter.
The Digi-out cards AES/EBU connector should go to the digital input of the Gen. VIII, then the Gen. VIII outputs analog to yer 6-Shooter in place of the two cables that would have come from the Xtreme DAC card, which will now go unused.
Connect the Data Vol. control cables up from the Gen. VIII and the
6-Shooter to the two Data control ports of the CB-IIIHD, which now includes one on your Digi-out card and your just about home....no?
Or consult this guy named Craig, goes by VGI round these here parts.
I here he's pretty good at this sorta stuff!
post #762 of 5098
So you're up and running too?
That's great!
You two guys that actually have the Gen. VIII and 6-shooters can fight out who's got it right!
post #763 of 5098
oops.. Sorry Stick, I see you left out a part to make Steves quote appear in your post.
I thought that part read kinda familiar already!
Sorry bout dat, I guess your still waiting?
post #764 of 5098
Steve besides connecting the data out from the CBIII to the Gen VIII, I believe you have to also select which channels in the Gen VIII menu that you want it to respond to volume commands from the CBIII. You have the option of Left and Right, Center and Sub, etc, but I believe you do have to select. Otherwise the volume will increase as you increase the volume on the Casablanca, but the channels may not be balanced.
post #765 of 5098
When using the CB-III or CB-IIIHD in conjunction with a Gen VIII, you'll need to select a particular input on the Gen. VIII, to be used from the output of the CB-III, and simply set Unity Gain to ON for that input In the Gen VIII?
This makes the Gen VIII output at full output all the time, for any of it's givin inputs, (not channels as I understand it), then the volume output to his 6-Shooter (or amps if someone is not using a 6-Shooter) will always be the same and all the level balancing can and should be done within the Casablanca, for only that input selected, all of the other inputs can still be used as a pre-amp for those inputs and still have variable output from any of these.
If you leave it to act as a pre-amp, AFTER being feed from the CB III-HD, like the way it's currently set-up for of you guys waiting on your upgrades, then it would present this problem, but only if you actually allow it to control volume AFTER the CB III-HD.
It won''t happen if Unity Gain is ON for the input in question.
It seems I always say, don't you "simply" do it this way or that, when I don't have one to play with!
Everything is simple from my armchair
post #766 of 5098
Originally Posted by bigbrother52 View Post
When using the CB-III or CB-IIIHD in conjunction with a Gen VIII, for the assingned input selected to be the input of the CB-III, don't you simply set Unity Gain to ON for that input In the Gen VIII?
This makes the Gen VIII output at full volume all the time, for any of it's givin inputs, (not channels as I understand it), then the volume output to his 6-Shooter (or amps if someone is not using a 6-Shooter) will always be the same and all the level balancing can and should be done within the Casablanca, for only that particular input selected, and it can still be used as a pre-amp for the other inputs and have variable output on all of those.
That's just using the Gen VIII as a preamp. Seems like Steve's intention is to use it as a dac instead of using the Xtreme dacs? If you set-up to act as a dac with volume control, the Xtremes are not used for those channels. That's the way I intend to do it. They way you describe would just pass through the output from the Xtreme dacs? I know you luv those Xtreme dacs but?
post #767 of 5098
I won't lie, I kinda like the xtreme DACs but Nah Nah Nah, I said in the begining that those two xtreme ports will remain unused and go to the 6-shooter and be fed from the Gen VIII.
I was laying out exactly how NOT to use the Gen. VIII as a pre-amp when hooked to a CB III and how to use the other available inputs pre-amped.
Straigten up and fly right boy
post #768 of 5098
Would not you just switch inputs? Then you are using the Gen 8 as a preamp for whatever source selected? Volume control of the Gen8 seems to operate largely the same as a Six Shooter when slaved to the Casablanca. One can also use it stand alone.
post #769 of 5098
Yes that is correct. I have set several inputs in the Gen 8 to use with the CB3 ie. one for HDTV and another for DVD. For those inputs I'd be using the Gen 8's DAC's for the L&R channels inconjuction with the Extreme DAC's in the CB3 for the rest of the channels.
The other inputs in the Gen 8 I use as a preamp for 2 channel stuff. Works seamless.
post #770 of 5098
Marc, Bulldogger is correct. I do not want to connect the CB3HD's front left and right Extreme DAC balanced outputs to the Six Shooter or Gen VIII, cause if I do then I am not using the DACs in the Gen VIII.
post #771 of 5098
Yes, I did that. You are correct.
post #772 of 5098
Bulldogger is correct again. He hits the Grand Slam!
post #773 of 5098
You sound like Obama taking credit for the biggest spending cuts in history, when his initial position was 0 spending cuts.
Congratulations. In your retirement, you will make a good politician.
But thanks for trying!!
post #774 of 5098
OK Dude!!!@@@
I got it all to work.
When I first hooked up the CB3HD, Gen VIII and Six Shooter:
1. CB3HD center, left and right surround, and sub (chaining three Aerial subs) into Six Shooter. Lft front left and right unconnected.
2. CB3HD data cables (2) connect, one into Six Shooter, one into Gen VIII.
3. CB3HD digital AES/EBU cable connects into Gen VIII digital AES/EBU input.
4. Gen VIII, one of the inputs, set (A) volume to fixed, and (B) "External Volume Sig Channels" set to front left and right.
5. Connected front left and right analog balanced interconnects, from each Citadel 1.5 monoblock, to the outputs of the Gen VIII.
Digital sources worked fine this way.
Haven't tried multi-channel analog or stereo analog XLR from UD9004 yet.
Does this setup make sense???
post #775 of 5098
OK Dude!!!@@@
Yup sounds about right to me. Just remember you use the external Vol Sig Channels with the Gen 8 and Six shooter and your fixed vol when using the Gen 8 as a stand alone.
When you can let us know about sending SACD / DVD-A over HMDI using the Gen 8.
post #776 of 5098
I'm very happy that you've got it all up and running.
Although, I don't know where I went wrong in my statement but I never suggested anything be connected to the extreme DACs, I thought I was clear from my first post last night that those two channels now go unused.
OK Dude!!!@@@
Your Step 4. is what I was trying to explain when this all went south.
The volume needed to be FIXED on the one input, that was my point.
post #777 of 5098
The only reason to keep the six shooter in the setup is to run SACD MCH analog through it. If you do SACD over HDMI you do not need the six shooter anymore.
post #778 of 5098
I agree. Good news is if he likes the sound of SACD over HMDI you can eliminate the six shooter.
post #779 of 5098
Bad news is if that is the case he might as well sell his beloved ud9004 and get an Oppo.
post #780 of 5098
Not Oppo, but Compli Blu!
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
