Originally Posted by BufordTJustice
Further, the Rhythmik would have about exploded with any amount of EQ added, so after switching the subsonic filter to "on" and deciding on a cutoff freq, that's all you can do there. Same with the CS 18.2 (the amp would have run out of gas even SOONER). The HSU and Epik may have been able to accept some EQ, but with reduced headroom (the Epik already uses, to good effect, a small amount of internal EQ). The most time fiddling would have been spent with the A7s-450, because it can tolerate more EQ added due to it having the most headroom. I suppose that would have made the test skewed...but then, again, eD MAKES the eQ.2...so maybe it's not unfair to use it with a product it was designed to be used for. Most of the other subs are running at redline, the A7s-450 has the most potential for tweaking. That was borne out by measurements and by listening experience in the review. Considering that tweaking costs exactly ZERO dollars, I would think that many end-users would take advantage of the added potential.
Just to give an example of eq'ing with the a7s-450;
During the Hulk sound cannon scene, I max'd out at around 118db with Audyssey off. I turned Audyssey on and replayed the scene; my max was still 118. I have graphed my FR response for both Audyssey on and off, and in my room, Audyssey starts to apply boost at 16hz down to 10hz. At 10hz, it's boosting 9db.
I agree with the reviewers by not choosing to eq because it acheives one of the things they wanted to do; provide the most useful information to the largest audience.
However, most people that buy sealed subs eq them as that is one of the benefits of a sealed sub. By flattenning your response and obtaining the lowest extension capable by your sub, your 'sound quality' will improve (dramatically for most) as it represents what the director/artist/etc. intended for you to hear. Having more headroom will allow you to keep that flat FR response without distortion at high volumes. I'm sure the sealed subs in this shootout could achieve that FR response, but the question is; but at what cost? Distortion? Could they achieve similar clean output numbers?
It would be interesting to see how/if that would change the results...I think many would find that useful because that more likely represents what most folks would do when they integrate it into their home theater. My .02
...will it be really objective?...will it be really professionally donne?...uhhmm sorry i am now doubtfull....
