AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Pioneer VSX-03TXH & Polk PSW 110 Sub Setup Help
post #1 of 2
What would be the best way to setup these two?
What I have setup now---
Sub settings:
1. Low pass set to LPF (sub says to set it here when using LFE out from AVR)
2. Phase control set to "0"
3. sub volume around 60%
4. Using sub cable from LFE in to AVR
AVR settings:
1. Sub mode on
2. All speakers set to small
3. Speaker crossovers set to 80Hz
There is no low pass filter setting in the Pio unfortunately. Should I keep it this way or set it up to have the sub's low pass knob on 120Hz and not let AVR process it?
Thanks in advance guys!
post #2 of 2
The crossover frequency you select in the AVR sets the HPF for all "Small" speaker and LPF for the sub. So, while there isn't a separate LPF setting for the sub, the receiver is applying 80Hz LPF to the sub.
Generally speaking, the sub/AVR connection and LPF/crossover settings seem correct to me.
