AVS › AVS Forum › Other Areas of Interest › Car Audio, Video, and Nav › 25hz hipass filter.....Help
post #1 of 9
So, I need a hipass filter at 25hz and I " thought " there was an inline type I could use in-between the preamp and power amp for my sub.
The sub is a horn loaded design and would benefit.....oh, and my active two-way XO doesn't have a hipass ugh......
post #2 of 9
Harrison
post #3 of 9
Not sure what you meant Mr R ?
post #4 of 9
post #5 of 9
ahhhh the good ol fmod!!
Also look on your amp for a SSF. it's the same thing.
post #6 of 9
Originally Posted by Kal Rubinson View Post
http://www.hlabs.com/products/crossover/
Perfect, the 30hz@12db should do the trick....Thx
post #7 of 9
Harrison
Kal, why no love for these little filters from others ? They say they are useless. I'll run some sweeps to see what it looks like inroom once the system is complete.
I think the garage will need some absorbers. It's rather lively . BTW, my corona froze up while listening to YES Going for the One...it's 8 degree's out !!! Geez, somethings gotta give lol
post #8 of 9
I have no idea. I have never used them but I have used similar and I have built similar. But, run your sweeps and decide for yourself.
post #9 of 9
Ok
  Back to Forum: Car Audio, Video, and Nav
