Hi,
Just bumped into this forum and think its great! You guys have offered some fantastic advice.
Wondering if anyone can help with the following:
I went to a sound shop to demo speakers. I found 2 equivalent models in the same price range - The Jamo S606 set and the Polk Audio Tsi-400 set with CS10 center and Tsi-200 surrounds. (I'm looking at the Jamo Sub300 for both systems).
I heard both of the systems and really can't make up my mind... sometimes the Jamos sounded better, sometimes the Polks sounded better.
The only thing pushing me more toward the Polk is the speaker design and the larger center (which seems like it would result in better movie dialogue).
My system will be used for home theater only, not music.
If anyone has managed to play with both systems in a similar set-up, would you be able to advise the pros and cons and which one to ultimately buy?
Thanks a ton!
Thanks a ton!
