AVS › AVS Forum › Blu-ray & HD DVD › Dual Format Players › LG BH200 PAL Question
post #1 of 3
I had a question regarding PAL playback on the BH200. Sorry if this has been addressed already, but I haven't been able to find a definitive answer.
Anyway, I've read that the BH200 outputs PAL/50hz content at 60hz and that the player allows NTSC-only TV sets to display PAL properly at 60hz. So my question is does the fourth field in the EEPROM setting have to be set at 00, or 80, in order to play SD PAL DVD content on a non-50hz capable TV?
Thanks in advance...
post #2 of 3
Originally Posted by zombi3 View Post
i had a question regarding pal playback on the bh200. Sorry if this has been addressed already, but i haven't been able to find a definitive answer.
Anyway, i've read that the bh200 outputs pal/50hz content at 60hz and that the player allows ntsc-only tv sets to display pal properly at 60hz. So my question is does the fourth field in the eeprom setting have to be set at 00, or 80, in order to play sd pal dvd content on a non-50hz capable tv?
80
post #3 of 3
Thanks. I was thrown off by this from the FAQ thread:
If your TV doesn't support PAL, use these alternate codes (if you're unsure, use these codes!): Region A - 00, Region B - 20, Region C - 26
  Back to Forum: Dual Format Players
