New here, maybe the wrong place to post this? and maybe kind of long but I'd sure appreciate some advice so I don't make the wrong choices...
Currently have 2 old TV's
Getting 2 new TV's
Have 3 kids.
Old TV's:
42" Toshiba rear projection Cinema Series (HDTV "ready"?).
28"? Toshiba Cinema Series tube.
New TV's:
47" Vizio XVT473SV (backlit LED LCD) - going in living room
37" Vizio XVT373SV (edgelit LED LCD) - going in master bedroom
Current Dishnet equipment:
508D in living room. We use the DVR a good bit.
311 in master bedroom -- (if we had DVR it might get used some but pause would be nice.)
Ideally I would like to have
View HD content in both Living room and master bedroom
Major DVR capabilities in Living room.
Would like to view HD DVR content in the master bedroom. At least have pause type capabilities.
SD feed to small Toshiba in kid's bedroom1 (42" projection will go into kid's bedroom 2 and be dedicated to an Xbox.
The Vizio's both have wireless N capabilities (don't know if it's only through the supplied Vizio Internet Apps or if I could stream other content to them).
I have a wireless network in the home with a d-link DIR-655 Extreme N router.
I could get a 722K for the living room and TV2 would be the old Toshiba in the kids room. Then maybe a 211 in the master bedroom ... but no dvr that way.
I could get 2 612's but then DVR'd content would only be available where it was recorded -- could not watch dvr content recorded in the living room in the master bedroom (and certainly not in HD). and visa versa. And the 612's are single tuner only? so the kids would be out of luck in their bedroom.
If I got a 722K with a sling adapter (or a 922K) could I sling content to the Vizio in the bedroom?
What is the quality of sling'd HD content? or is it only SD? Is there a bandwidth issue? if I have other things going on the network? The DIR-655 does have the capability to configure some sort of QOS to allocate/prioritize bandwidth based on content? or destination? or something.
I'm fairly computer/network savvy. I am perfectly capable of complicated wireless setups/configurations. Like maybe dd-wrt another couple of wireless routers into the network, or subnetting it, or stuff like that.
I just have to make a decision on the Dishnet hardware in the next couple of days. Any advice would be greatly appreciated.
I think it's basically:
3 tv's (maybe 4). 2 HD and 1 SD. Ideally, I would like to share all DVR content.
Getting 2 new TV's
Have 3 kids.
Old TV's:
New TV's:
