Originally Posted by FOH
I've never really paid close attention to sand filled stages. If one is sand filling for resonance control/solidity, couldn't similar non-resonance attributes be accomplished by filling every-other stud bay? Cut the work in half,..? Again, way out of my wheel house here with stages, etc., just merely inquiring.
Also, one of my fave builds around. Simple, yet extremely thorough execution of all aspects. I'm excited wrt your audio system. Those mains, I'm sure are superb (especially for music). Being a fellow IB enthusiast, I'm really looking forward to any measured response, but most of all your subjective reaction to bass done right.
Congrats on the progress.
All the best
All the best
Thanks for the compliments. I'm really excited to get my speakers set up. You might be right on the stage. I'm not sure how necessary it is to fill up the entire stage, but I figure that the more mass is better and its easy enough to do at this point. The front steps and the two little wings will just be filled with insulation. I am going to run a conduit from the back of the stage to each side of the front of the stage that I can use to run speaker wires for floor standing speakers. That way I can still listen to monitors or floorstanding speakers for music listening without placing them behind the screen. I'm going to try the PBN's behind the screen and see how they work but will have the option to have speakers behind the screen or out into the room.
I've also been thinking of building some 3pi horn speakers using the B&C De250 compression driver and the Acoustic Elegance 12" driver. I'm not sure I will need the additional output as the PBN's were as loud as I ever needed them to be and that was in a bigger room (18x33) than I have now. It seems everyone is doing horns these days so I thought I would see what the buzz is all about. I will say that most of the horns I have heard I have not been too crazy about, but do have limited experience with them other than through concert venues and such.
