Desert Sunset Theater Build - Page 13
post #361 of 1098
I do not seem to have very good luck with these rotary tools. Maybe I should move to an air powered die grinder.
I think the air powered grinders require a lot of air, which translates into a pretty big compressor. That's workable if you're only going to use the tool in the shop or garage, but bringing an air powered tool in the house for a quick job is not very practical. Electric tools are more convenient for homeowners and hobbyists, IMO.
post #362 of 1098
I was about to buy one the other day and saw that it required 5 CFM. My compressor is definitely not up to that task. My philosophy is usually that If I use something enough to wear it out, then I replace it with something better. In this case I may just buy the $30 black and decker model and treat it as disposable.
post #363 of 1098
Stockmonkey, looked through your thread, nice build thread. You are going to love the the IB. going to be quite the theater with that star ceiling. Have you decided on what speakers you are going to use. I saw in the thread where you mentioned several different choices.
post #364 of 1098
I'm going to be using the PBN audio EPS with a custom EPS center channel. Rear speakers will be the PBN monitor. Side surrounds will also be custom from PBN.
PBN EPS -
PBN Center
PBN Monitor
post #365 of 1098
Those look like some serious speakers!
post #366 of 1098
Love the pics. You've posted pics of the custom center channel, but seeing those tower mains,...damn,.....sweet.
post #367 of 1098
The current plan is to use the PBN's but I was also thinking of building some 3pi speakers with the AE TD series woofer and B&C compression driver. I wanted to try a high output design in the theater. That being said, I'm not planning on doing that anytime soon as I'd like to delay any additional projects until the theater is done. The PBN's though are still pretty high output and should give me reference levels or at least as close as I can stand in the room. They performed incredibly in a bigger room in my last theater. They are rated at 92db but Stereophile measured them a bit higher than that. They are also very dynamic and handle lots of power and seem to just keep going and going without any strain. Purely from a sound quality perspective they are hard to beat in my opinion. I've listened to many high end speakers and there are not many I have heard at any price that I would rather have than the PBN's.
I really question whether something like the 3 Pi's or some of the other pro style designs can beat the PBN's from a sound quality perspective but I'm interested to hear the dynamics of a speaker like that in the home.
Even though I will likely use the theater more for movies than music, the music performance is still a higher priority for me. I listen to music a lot more critically than I do movies.
post #368 of 1098
Nice build. I'm doing something similar with the IB in the front - well, once I get going again.
post #369 of 1098
Well its been a couple of very frustrating days on the theater build. I had a few issues with the star ceiling. I did not paint the panels prior to putting them up. I got the first 2 panels up and noticed that there is a few spaces where the fabric is sagging a bit. Not a lot of sag but enough to bother me. I figure that it is because the glue was getting soaked up into the wood. I used nearly an entire can of 3m spray adhesive per panel. I primed the other 3 panels and it did not take nearly as much glue and held much better. I stayed up late last night running all the fibers and getting the 3rd panel ready to put up. It takes me about 5 hours to put up the fabric and run all the stars for each panel.
This morning I lifted the panel up and put it in place at about 10 AM. When I got it up, to my dismay the fabric did not match. It was not the direction the fabric was installed, it was simply different. The pile on the velvet was not as thick and had more sheen to it. I held the remnants from that piece of fabric up to the rest and no matter which way you turn it, it is clearly different. Not dramatically so, but enough. I noticed a similar thing when looking at the fabric store, some bolts had more sheen than others even though it was the same sku. I ordered 20 yards online so it would all come from the same batch but I received 2 8 yard bolts and a 4 yard piece. The different piece is the 4 yard section. Anyway the panel had to come down, have the stars removed, the fabric ripped off and I had to start all over. At 8:00 PM, I had the new fabric on the panel and had it ready to lift up to the ceiling. In other words, 10 hours of work to get to where I started the day.
Here is a photo of what the 3rd panel looked like. You can see how much darker the first two panels are. Its harder to see the difference in the photo than in person.
post #370 of 1098
Ow what a pain - I had that happen on one of my wall panels, I think due to having the material reversed (looks the same both sides to the naked eye - until the panel is up ) - yours is obviously more impactful due to the size and fibers.
post #371 of 1098
This star ceiling installation has been quite the test of my patience. With the re-done 3rd panel up, there is even some variation in color in that panel also. Its nowhere near as bad as the first time I put it up, but it will definitely bother me. In addition, I have some fabric sagging in that panel also, despite priming the panel and using lots of glue.
After much deliberation, I decided that the stretch velvet fabric is not the right material for the job. I thought the velvet would look and perform nice and the stretch velvet is fairly acoustically transparent. In addition the stretch velvet seems to be the only velvet fabric wide enough to cover a 4 foot wide panel. The big problem is that the glue does not adhere to the back of the fabric very well because it has a very smooth shiny back. I think the stretch also makes it difficult to glue and you have to avoid stretching too much or it makes the fabric look different.
While it really hurts to go back and re-do 25 hours + of work, I think that is what I will have to do to make it look right. I did some experiments with some GOM FR701 fabric and it is surprising how much better it sticks to the panels and how much easier it is to work with. So I placed an order with Fabricmate today for GOM Fabric. All I can say is I hope this is all worth it when all is said and done.
post #372 of 1098
What are the reasons for using an acoustically transparent fabric over the MDF panels? I ask because I just received the Triple Black Velvet from Sy Fabrics and the Black Stretch Velvet from Joannes today. The Triple Black Velvet is definitely not as AT as the Stretch, but it has a nice uniform flat back, and has a much darker front. I can't tell you if the sheen is directional until I get it installed tomorrow though.
post #373 of 1098
Ouch! After all the uncompromising work you have done in that room there really is no other choice. Deep breath...persevere. It will be worth it.
post #374 of 1098
If it makes anyone feel better, I've redone more things, taking more countless hours than anyone.. starting with tearing down the original framing i had done before finding the forum, going back, cutting out and reinstalling 3 layers with GG to redo my HVAC plan (or actually the lack of one) etc..etc..
On a side note.. I spent alot of time, as do many, looking for a substitute for the GOM also. I felt like it looked like Burlap. but honestly after working with it and getting my panels done, it does not look Burlappy at all.. it has a nice clean look when installed.
Brad
post #375 of 1098
if you have a large surface like the ceiling that absorbs only the high frequencies, you run the risk of making the room sound too dead especially when used in combination with broadband absorbers around the room. Some of the thick velvet I have seen would attenuate the high frequencies too much. Its best to have broadband absorption but even that can be used too much.
post #376 of 1098
Not sure how much stretch velvet you ordered but just watch for the inconsistency between bolts of fabric if you ordered more than 8 yards. I went in to a Joann's store to check out the velvet and noticed the variation in sheen between the different bolts there also. Some were very black and some had an almost blue sheen to them, yet they all had the same SKU number. You also need to be careful about how much you actually stretch the fabric when applying it, If you have too much stretch it will look lighter. It really is a pain to work with and appears to be a crap shoot whether the fabric looks the same.
post #377 of 1098
I love the build thread! Nice attention to detail and workmanship. Was that a Christmas tree I saw?
post #378 of 1098
Yes that was a Christmas tree - Those speaker pics are not current (with the exception of the center channel), I just put up what I could find. They've all been boxed in their crates now for over a year.
post #379 of 1098
Last week I ripped down the old ceiling and removed all the fibers and fabric. I primed the first two panels. I found that I had to re-drill all the holes after the primer went on because it was too hard to get the fibers through. My fabric arrived late last week so I started putting up the new panels. The Guilford of Maine FR701 was much easier to work with than the velvet. It was easier to apply, easier to get the fibers through, and most importantly, the glue actually sticks to it.
I managed to get 3 panels put up, so I am officially back to where I left off on Friday of last week. I'm very happy with the way it looks with the GOM fabric.
Here's a shot of where it currently stands.
post #380 of 1098
Ah ok, that makes sense. Thanks for the clarification.
I noticed you mentioned that. Mine came from a single bolt and looks black enough to keep me satisfied. I only needed 2 yards to make the CIH masking.
The new GOM looks great. And I'm glad to hear it was an easier process, though you seem to have had enough practice to do it a few more times .
post #381 of 1098
The velvet would be fine for a small area like that. I plan on doing velvet around the screen area. The last few panels have gone up without a hitch, I am getting much faster at it now I've spent so much time doing it. Those huge MDF panels do not seem so heavy anymore.
post #382 of 1098
Getting ready to apply fabric to the last panel.
post #383 of 1098
All the fibers run for last panel.
post #384 of 1098
Ceiling panels all installed.
post #385 of 1098
I know I'm late to the party but ur build is looking awesome! I can't wait to see it continue to come together!
jim
post #386 of 1098
Running all the fibers into the illuminator was literally a big pain in the neck (and back). Standing on a ladder for hours with your hands above your head was quite exhausting.
post #387 of 1098
Star ceiling is completed. This project was a huge pain but now that it is up it has all been worth it. I figure that with the issues I had with the first fabric and having to re-do quite a bit of work, this project took me close to 100 hours. I hope to never have to do another one of these again, but If I did I could probably cut that down to 40-50 hours or so.
Here are some shots of the stars taken with my little point and shoot. The photos do not really do it justice.
post #388 of 1098
Nice job,..I realize the camera doesn't even come close, but what you can see is fine and I'm sure the entire thing is great. I've never considered anything like that, but I'll tell you, I'd bet it elicits a very pleasant effect.
Congrats, that's a significant amount of work.
post #389 of 1098
Looks kick ass in the picture, and I'm sure kick-assier in person. Congratulations on grinding through it and reaching that milestone!
post #390 of 1098
Looks really good. Nice work.
Question for you. In the photos, it looks like some of the lights are brighter than others. Is that what is actually happening or is that just the photo?
