Desert Sunset Theater Build - Page 16
post #451 of 1098
Started work on the columns. Still have to put in a backer for the translucent panels and do some sanding.
post #452 of 1098
Moving right along,...thanks for sharing.
post #453 of 1098
Today I sanded the columns, applied a sanding sealer and then sanded a final coat. I also picked out a couple paint colors to try out.
post #454 of 1098
Nice!
post #455 of 1098
Here is a couple of shots of the paint color for the walls. The color is quite a bit darker in person than in the photos.
post #456 of 1098
I didn't see any pictures up close of your light tray and with decent light. Is your light made of MDF and what color on the under and out side did you make it, or is it not even colored/finished yet? I'm getting ready to do my light tray and wanted to see how you did yours since mine is going to be a very similar design. Your theater is looking great btw.
post #457 of 1098
jman - I'll take some shots of the underside of the soffit today. The light tray is made of MDF and is currently not painted but is ready for paint. My plan is to get the woodwork for the soffit painted today and as soon as that dries I'll make the cloth panels that will go on the underside. Hopefully all the soffit work will get done this week.
post #458 of 1098
Awesome. That would be great.
post #459 of 1098
Your room is shaping up really nice. Great work.
post #460 of 1098
Thank you for sharing your wonderful photographs. In a way, daunting for me as I know nothing about "building stuff", but inspiring because I love movies and dream to build a theater some day.
I am reading as many post as I can, to learn..but would you suggest a place to learn all the acronyms that people frequently use.
And since I did not grow up in US of A, I never had any one teach all the woodwork and handy work. Would you suggest going to home depot or lowes- and do they have some classes to learn it?
P.S. I loved your ceiling-I see many people love your speaker construction, but as a novice- I know little about it to admire, but I can definately admire the ceiling.
post #461 of 1098
Thanks for the comments. This has been a really fun project and while I'm looking forward to it being completed, I will be a little sad not to have it to work on. I don't know of a place where you can find the acronyms people use - You just pick up on those by reading. It would be a good idea to start a sticky thread on this forum with the common acronyms though - I remember being confused with stuff acronyms like GOM (Guilford of Maine Fabric) and OC703 - Owens Corning 703 rigid insulation.
About 15 years ago I had very little knowledge of this stuff. Then I started buying houses that needed work and fixed them up. My wife and I would buy a dump - move into it and spend a few years fixing it up, then sell and move into the next dump. I have a father in law that is a contractor that taught me some skills, but when it comes down to it often you just have to jump in and figure it out. Most of this stuff is not rocket science and getting good results has more to do with time and effort than skill. I've never taken a class at Lowes or Home Depot, but I'm sure it would be a good place to learn some basics. The theater construction was somewhat unconventional for the most part and this forum is priceless when it comes to theater specific construction.
I would suggest acquiring a few basic tools and diving in and learning by doing. It doesn't always require high quality tools. They can make things nicer but the job can usually be done with cheap tools. I have a really crappy table saw that hardly cuts the same twice but I'm still pretty proud of the job I did on the soffit woodwork. There were times I had to compensate with some wood filler.
post #462 of 1098
Here are some shots of the soffit woodwork with a coat of primer. Hope to get these sanded and get a coat of paint on them tomorrow.
post #463 of 1098
YEAH! Those look great!
post #464 of 1098
Looking great. I really really like ur soffit design!
post #465 of 1098
My wife is a much better painter than I am so I talked her into painting the woodwork yesterday. I'm fine with a roller but she is much better at cutting in with the brush. Not that it matters now that I already got some primer on the wall. She managed to get most of the first coat done but there is still a bit left. Once the woodwork is done, I 'll put a 3rd coat on the wall to finish up.
I also ordered a bunch of different Guilford of Maine fabric samples from Fabricmate. Not sure if I will use the fabric I showed earlier, I think it might be too busy to have that much fabric with a pattern. I did use the colors on the fabric as my color scheme though.
post #466 of 1098
Awesome pictures. That's exactly what I needed to see. I was thinking of doing it the same way for my light tray but wasn't quite sure how it would work. Thanks Stockmonkey.
post #467 of 1098
Your HT is coming along great Stockmonkey! I really like the star ceiling and would love to do one myself one day. Looking forward to seeing the end result (subscribed)!
Have you decided on a projector yet? Some time ago you talked about JVC and Panasonic. I assume that was in order to get the lens-memory features or are you considering using an A-lens for scope?
Dare I ask when you expect to be finished with the build?
Keep up the good work and be sure to feed us with a lot of pictures
post #468 of 1098
Blue rope light has been installed. It was very uneven when I first put it up but I faced all the LED's pointing down and it looks much more uniform.
This is what it looked like without the LED's all pointed the same way.
post #469 of 1098
I just talked to AVS yesterday about the JVC RS-45. I thought about ordering it now but thought I would wait until I'm a bit closer. No sense in having it sit in the box with the warranty ticking away. I'm just going to use the zoom feature for now. I'll probably order the screen early next week. I'm going to be using the Seymour Centerstage XD screen.
As far as a completion date I'm not really sure. If I stay motivated I could be done with the theater itself in 2-3 months. Its really starting to take shape but there are still quite a few things to do. I will also have to do some work on the equipment room and still have more to deal with in the basement. To get the entire basement done I would expect that to take several months. When the theater is functional I think the work on the rest of the basement will be much slower. Fortunately the remaining unfinished part is fairly small.
post #470 of 1098
Reasoning for going with Seymour over SMX or other brands?
post #471 of 1098
I'm using the Centerstage material and will build my screen. So mainly price and availability of the DIY Fabric.
post #472 of 1098
Wow, this looks so good! You've done a great job. Have you decided on carpet?
post #473 of 1098
Excellent tip about the LED rope lights. That's the same color as I'll use, so that makes me even more excited to her mine done.
post #474 of 1098
That second pic is how rope like usually looks in my experience which is the reason why I have always hated rope light. You, you talented devil, have managed to install the first rope light that looks good to me! VERY well done, friend!
post #475 of 1098
I have not decided on carpet yet, but Ive chosen paint colors and fabric already. I hope that does not limit my options too much. I really like the carpet Brad Horskotte used in his theater. Not sure if that will work with my colors though.
I'm going to try and look at some carpet this week.
post #476 of 1098
Thanks for the comments. I'm pretty happy with my blue rope, but not as happy with the white. I'm thinking of trying an LED rope with the white. the white looks more washed out against the black fabric and the black part of the soffit. I may change the front of the soffit to another color to reflect the white better, but when the rope is off I think the black is best for the star ceiling.
There are a couple things I wish I would have done differently. I wish I would not have put the inserts that hold the rope light in permanently. I wish I had a way to adjust the height within the channel, then you could control the light spill better. I also wish I had used the plastic channels instead of the clips i used, I think the channels would give you more control over the position of the rope. My rope is held by clips every two feet.
I experimented in building a light diffusor in the soffit. I took a lexan plastic tube that is used to hold flourescent light bulbs and sanded it rough then cut it in half and put it over the rope light. It did not work so I worked with the positioning of the LED's and got much better results.
post #477 of 1098
Stk2k - great progress and the soffit lights look really cool. Your "I wish I did this..." comments; I think we all have a full list of those
post #478 of 1098
Here are some shots of the soffit woodwork with the first coat of paint. Some of my pics are a bit blurry.
post #479 of 1098
post #480 of 1098
Looking pretty sweet. Thanks for the pics.
