Thanks for the info - I really appreciate it. I called Digikey and they recommended a substitute for the discontinued fan, Part # P14751-ND. It is 2 sones quieter, 2.1 CFM more air volume, 0.39 less watts in power consumption and double the rated hour life at 100,000 hours. Price is $8.15 for one, fyi. I'll post on how my swap-out goes. Here's a link to the new fan
http://search.digikey.com/us/en/prod...751-ND/2615564
I am sure Behringer's fan was designed to be operational in 95 degree heat at some sort of summer music festival where the demands are large and constant in these extreme conditions. I opened a case up with the tech folks at Behringer regarding cooling options under residential loads in a climate-controlled environment just for kicks...
