post #1 of 1
Howdy!
I was hoping you could help me with my samsung TV. I have it hooked up to my PC via the VGA port on the back.
There is a fair amount of ghosting on the screen, that I can't seem to be able to fix.
The tv is currently running at 1360x768, which seems to be the standard PC resolution.
The ghosting isn't much, maybe an 1/8th of an inch at most, but its noticeable and annoying as hell. It shifts from side to side.
Thank you, hope someone can help!
