[/quote]I'm not sure what the measurable audible difference would be. But you could do some interesting things with an oscilloscope setup to measure sound (there probably is a more appropriate tool than an oscilloscope) waves and compare them. You would find, depending on the quality of your tool, slight or even large differences, probably dependent on speaker quality.[/quote]
Im saying if you play a 200hz sinewave on two different speakers the only difference possible would be volume. If you put them in one room or another or stand in different areas the only difference would volume what other diferences could there be the room. I get that the energy from the sound could be making other sounds from objects in the room or that the speaker cone itself from the vibration could be making its own natural sounds.
Also I would like to know if we agree on this all speakers do is vibrate back and forth. For example if you took a 20 second clip of a sound wave from a piece of music and flip it on its side and had it play the speaker would be moving back and forth according to the changes in the shape of the wave?
I dont see how it cant do this without serioulsy altering the sound and last time I checked if it moves any slower or faster you would be changing the frequency or in other words the key of the song but Ive never had to change the tuning of my guitar to play along with a recording because I was listeing on different speakers. That problem only existed with tapes right?
Can you also tell me what im doing wrong with the quote function?
