AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › Taxi Driver 35th Anniversary edition
post #1 of 78
post #2 of 78
Great effort to secure the Criterion commentary. Also makes you wonder what title(s) Criterion got from the deal.
post #3 of 78
The BBS box set perhaps?
post #4 of 78
Just a heads-up - it's back down to 12.99 at Amazon:
http://www.amazon.com/Taxi-Driver-Bl...uct/B004IFYMYI
post #5 of 78
And...preordered. Never did get this on DVD (and I keep missing parts of it on cable), so this is a no-brainer.
post #6 of 78
Added detailed extras listing and cover art
post #7 of 78
Awesome interview with Grover Crisp, tons of insightful info: http://thedigitalbits.com/articles/t...interview.html
"Having said that, though, we don't take the position that grain is an automatic "problem", and we usually just leave it alone."
"Actually, Lawrence is not completed, yet, though we have begun work on it. It is a complicated project and will certainly take a year to complete. The 8K scans of the negative are done, so we are at least headed down that road."
post #8 of 78
That article is a great read. I'm not sure any other studio has shown the excellence in video mastering that Sony consistently has.
post #9 of 78
"film, regardless of what the particular element is, needs to be scanned at 4K at a minimum"
post #10 of 78
Universal & Paramount take note: "Most filmmakers know what they are doing with the resources at hand and our job, after all, is to replicate the vision of the filmmaker, not to impose our own aesthetic outlook on a film". STEP AWAY FROM THE DNR CONSOLE!
post #11 of 78
Man, $13 for a 4k restoration of a classic, now that's a great deal
I usually don't pre-order but I don't think there's anything to lose...
post #12 of 78
Other studios take note...THIS is how you do it.
post #13 of 78
I have been in Sony's Colorworks facility and audio post production in Culver City and it is hard to envision a group that would be better equipped or dedicated to quality.
A high percentage of their work is for other studios. Many well known films with other studios pass through their shop.
post #14 of 78
Another article on the restoration... this time with 1080p screenshots!
http://magazine.creativecow.net/arti...-driveri-in-4k
post #15 of 78
Originally Posted by Article View Post
"He notes that the entire last scene in the apartment was an optical. "When they showed the film to the ratings board originally, it got an X rating because of all the blood in that scene," says Ostrowsky. "They went to a lab that did a Chemtone process that gave it a desaturated look." Although today's films don't shy away from showing blood, the 4K version of Taxi Driver features that same desaturation. "We kept it the same," says Ostrowsky. "Michael [Chapman] did not want to change it and we kept true to what the print looked like.""
Dammit... I'd hoped to see the killing scene restored to it's saturated glory...
I remember it being discussed in the audio commentary of the old DVD release. They said the scene looked vivid like the bloody still photos taken and that they'd hoped to restore the scene to it's full colors but the negative had shrunk and faded so they couldn't do it.
Now it seems to me that they now could get the propor color-saturation from the negatives with some minimal digital color correction, but they WON'T! what gives...? They could use seemless branching to present an unrated cut as well as the desaturated r-rated cut. Aaaaaargh!!
post #16 of 78
I think the part in The Digital Bits' interview with Crisp where it is explained, is:
"...what I can say is that they delivered back duplicate negatives of these two sections, with the long sequence, in effect, now an optical dupe and with the desired color and density built into it. So, literally, when printing this film at a lab then (or now), there was no way to grade it and print it the way it was shot. Those muted colors are built into the dupe negative and it doesn't work to try to print it otherwise."
post #17 of 78
Interesting that they're doing all remastering work in 4K now...
"For some time, we have been scanning everything that we work on at 4K, regardless of whether it is a big restoration project or if we just need to re-master the film for Blu-ray"
post #18 of 78
In Sony we trust
post #19 of 78
Thanks Flexx , that's more explainatory than the other article. I feel much better knowing that only the desaturated negative dupe exists, and that they can't get it back to the original state even if they wanted, instead of the "we can do it but won't" attitude which was implied in the creativecrow article.
post #20 of 78
I really really really hope I'm wrong, buuuut, that really really really looks like AVC artifacting and not JPEG artifacting in those screens. The JPEGs are also 700kb, at that size and resolution there wouldn't normally be artifacting. Hopefully there's some weird circumstances that's causing that artifacting, (ie non-final encode shots supplied by Sony).
Anyway the article itself was also good.
Sony has in the past sometimes underestimated the need for higher compression parameters on films with dense grain structure, such as Taxi Driver. They tend to target their encodes to average in the mid-20s, which is fine for a clean, glossy film or source. But that level invariably breaks down on close inspection for messy sources. I have to believe that much of the compression process has been reduced to the level of automation. Hopefully a major restoration like Taxi Driver had a technician go over the video encode by hand and tweak any problem areas for artifacts.
The very high bitrates in the 30s we often see on foreign releases has proved, to me at a minimum, that compression transparency and fidelity to the master is visibly improved over the Hollywood studios' typical practice of targeting averages in the 20s. Of course it still surpasses the studio, which I do not even have to name and everyone stills know who they are, that is targeting sub-20 figures on all releases now.
post #21 of 78
Actual screenshots: http://www.blu-ray.com/movies/Taxi-D...5/#Screenshots
No compression issues. The CreativeCow article just got bad ones (deleted my relevent post). I knew Sony wouldn't let us down.
post #22 of 78
Blu-ray.com review is up.
Their screencaps kill the ones in that article. Seems to look excellent.
post #23 of 78
Wow. Just... wow. Looks absolutely *fantastic*.
post #24 of 78
Hello good day. This is a good movie too.
Regards
post #25 of 78
why cant all studios produce such good pq?
post #26 of 78
Money, time and effort, also an invested intrest in the platform's survival
post #27 of 78
And a guy like Grover Crisp who knows what he is doing.
post #28 of 78
Indeed, but he needs to get hired in the first place
post #29 of 78
Agreed.
I wonder what's going on with George Feltenstein (sp?) at Warners. I used to read interviews with him back in the DVD days and they did great work on DVD. It really seems like they've fallen off a bit with Bluray.
post #30 of 78
I think WB do good restoration work. It's usually screwed up downstream, with horrible compression.
  Back to Forum: Blu-ray Software
