Hello everyone,
Going to be making a cheap theater to tide me over until I get some quality components/retractable AT screen in the future (1-3 years). It's also in lieu of buying an LCD for gaming/sports and hopefully to put a fire under my wife to put a nice setup in the family room.
What I need is a simple mix, not worried if it costs $40 vs $80, just want something that is the easiest for a novice to put up and looks reasonably good (the largest/best TV I've watched for any length of time is a 52 1080p LCD so anything is probably going to amaze me). Here is the crucial info:
Just from reading through the various mixes the ingredients for this one seems easily accessible and it doesn't have a lot of components for me to screw up:
Any other thoughts or suggestions?
How many coats would be needed, 2?
- This will be rolled
- Screen size: around 100, probably 16:9
- Room dimensions: 15'x11' (opens to a larger area)
- Light controlled basement, two small windows but I can curtain or block them off if I feel like it. Although odds are there will be some ambient light at least some of the time (wife won't watch in the pitch black)
- Walls will be dark brown, ceiling will be white (I know, I know, may change that later)
- Existing wall will be used for screen, it's a light brown now so I'll prime it white first
- Not sure on the throw distance probably 13'-14' Just going to hold up the PJ and move, zoom until it fills the screen, then ceiling mount it
- PJ: Optoma HD66
- I have easy access to Home Depot, Lowes, Michaels and Sherwin Williams so I'd like to keep the components from those places.
- Use will be HDTV, PS3, PC (occasionally) and some Blu-Ray/DVD movies.
- 1 quart of behr 4850 flat
- 1 quart of Minwax Polyacrylic Satin (water based)
- 2 - 8 oz. bottles gleams ceramcoat pearl
- 1 - 8 oz. bottle gleams ceramcoat silver
