AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › Dirac LIve and High End Stereo
Dirac LIve and High End Stereo - Page 3
post #61 of 65
Originally Posted by noah katz View Post
I just had the same issue trying to run setup with my 11.1 system.
Turns out that Trinnov s/w insists that the sub be assigned to the highest number channel, so you'll have to adjust your speaker routing to match.
It is complete mess. I changed the mapping in Jriver and get the channel assignments right without applying a filter, but then when I use on of the filters they are mixed up again. I'm going to need help from Dirac to get this sorted out.
post #62 of 65
Just heard back from Dirac. Channel mapping in Jriver and Dirac are the same. Why mine gets screwed up is a mystery they cannot explain nor resolve. I hate HTPCs with a passion, but am so far into this now, I'll see this one through to the bitter end.
post #63 of 65
Instruction manual for miniDSP 2-channel Dirac boxes:
http://www.minidsp.com/images/documents/Dirac%20Series%20-%20DDRC-22%20User%20Manual.pdf
Worth a peruse.
post #64 of 65
Nice find, thanks Sanjay.
post #65 of 65
Worth a peruse.[/quote
Want! I see they are $899 + $75 for the mic
Edited by ddingle - 4/1/14 at 2:29pm
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
