Hello again everyone. As many of you may (or may not
) know, our family has been looking into purchasing a CRT Rear projection television. Many of the ones that are within our budget are older (2001-2007+ish era) that only support 480p and 1080i in for some reason, and not 1280x720p. I've plugged up a computer to a 1366x768 LCD television (dualview setup), and it was pretty straightforward, but beside with a composite plug, I've never output to anything interlaced before (obviously we won't be using the SVideo "TV Out"). I'm planning on using a VGA to Component adapter. The advertising pamphlet for the GMA X3100 card says that it supports 1080i, but I'm curious how you would achieve this. I've never seen any special settings in the standard Windows Display control panel or the Intel control panel to suggest 1080i.
Any suggestions?
- 2 Bunny
) know, our family has been looking into purchasing a CRT Rear projection television. Many of the ones that are within our budget are older (2001-2007+ish era) that only support 480p and 1080i in for some reason, and not 1280x720p. I've plugged up a computer to a 1366x768 LCD television (dualview setup), and it was pretty straightforward, but beside with a composite plug, I've never output to anything interlaced before (obviously we won't be using the SVideo "TV Out"). I'm planning on using a VGA to Component adapter. The advertising pamphlet for the GMA X3100 card says that it supports 1080i, but I'm curious how you would achieve this. I've never seen any special settings in the standard Windows Display control panel or the Intel control panel to suggest 1080i.Any suggestions?
- 2 Bunny
The owners manual should give you some information on what the input accepts. Have you tried sending it a 848x480 resolution with DTDCalc? It is an EDTV and that resolution might help. You might want to make a post in the rear projection forum to see if anyone there has configured the TV back then. The more I think about it there was some settings in the TV's service menu that needed to be changed. I wouldn't go there as you can make your tv unusable without knowing the proper setting or writing down all the current settings in the service menu.
