AVS › AVS Forum › Video Components › Home Theater Computers › Output 1080i Resolution on an Intel GMA X3100 Graphic Card
Output 1080i Resolution on an Intel GMA X3100 Graphic Card - Page 2
post #31 of 34
I'm still looking for a solution if anyone has got any ideas.
Thanks in advance.
- 2B
post #32 of 34
Any updates on this?
- 2B
post #33 of 34
That TV is not 3D at all. Not even a little bit. It also doesn't support Full HD, which is 1080p. It supports 1080i only.
If you insist on using the TV, the best thing to do would be to get a $30 video card that has component video output. That way you don't have to mess with any settings.
All that said, IMO your money is better spent on a smaller flat panel or DLP that's actually within your price range. CRTs are high maintenance and qualified technicians are not cheap.
post #34 of 34
Originally Posted by 2 Bunny View Post
Actually it is. It has 1920 by 1080 resolution (full HD) and the CRTs inside give a 3D effect.
Not to side track this discussion, but no, regardless of the resolution that set doesn't have the refresh rate or input capability needed for 3D. Period.
Further, the point others are trying to make here is that your set isn't anywhere near as capable of displaying computer video formats as current HDTV's are. Computer video formats and HDTV video formats are different and not compatible with each other. In 2002 a VGA input on an HDTV was for video devices (read: set top boxes, DVR's, etc.) that had VGA output, not necessarily a computer. A current HDTV will have the same VGA connector but the input can be from any number of devices, both video and computer.
To really figure out your problem, you need to get the specific computer display format(s) the Mitsu is capable of (which is most likely 1920x1080 interlaced), and find a way to set the graphics card output of your computer to that specific requirement. Otherwise your wandering around in the dark. This is not an Intel issue or AMD issue; it's graphics card output and HDTV input compatibility.
As noted, another way (maybe) is to get a component video card for the computer, but the output would have to conform to video formats. I don't know if component video cards do or not. EDIT: Since you have a laptop, this is a moot point.
This thread is locked
