Originally Posted by
ceaton
I'm thinking about putting together a Zacate system with an Antec ISK 300-65. This system would have no optical drive, but I want to put a normal 3.5" desktop HD into the thing.
Does anyone know if its possible to fit a standard desktop hard drive into this thing's optical bay with adapter rails? This case looks just about perfect, aside from not supporting desktop HDs.
I would say no, not with any off-the-shelf rails. This case requires a slim optical drive, and it has a bracket for two 2.5" drives above the optical drive. It looks like one 3.5" drive could fit in place of the optical drive if you remove the 2.5" bracket, but you would need to secure it with something other than the standard mounting screws.
See this Antec ISK 300-65
review.
If you choose a different mini-ITX case that fits a standard optical drive, then you can use a 3.5" to 5.25" adapter to mount a 3.5" drive in the 5.25" bay. Adapters are available from many case manufacturers, such as Antec, Lian Li, Silverstone, and Cooler Master. The
Silverstone FP55 lets you mount one 3.5" and two 2.5" into one 5.25" bay!
