What is the preferred 2CH audio out selection from an iMac to my preamp, USB or the 3.5mm headphone jack? Either output will run through a separate DAC before the preamp. Mainly listening to iTunes or Pandora.
If using the 3.5 mm output, a tosslink to mini-plug cable will be used to connect to the DAC. If using the USB output, a USB to Mini cable will connect to the DAC.
