AVS › AVS Forum › Video Components › Home Theater Computers › Low profile Audio card
post #1 of 11
I'm getting a small form factor Dell Optiplex for less than I can build system. However, it doesn't have S/PDIF, but there is a PCI slot for a sound card. I want the S/PDIF to plug into my low end Harmon Kardon 5.1 receiver. The receiver doesn't support sound over HDMI, so the new video cards that do that aren't an option.
I'm a litle confused about the cards though.
A nice card like the Xonar DX has the digital output. But does all the fancy capacitors and low SNR really help with digital output? Does that just help with converting from digital to analog, which I won't be using anyway?
If it doesn't really matter then the Xonar DG is a lot cheaper and has built in Optical SPDIF. Or the Turtle Beach Audio Advantage Micro II
Can anyone explain things for me?
post #2 of 11
Does your HK have discrete 5.1 analog inputs? My Denon doesn't have HDMI audio but the analog inputs sound great to me.
Other option may be build your own SPDIF bracket if your motherboard has the header (many do).
post #3 of 11
If your only purpose is send DD/DTS over S/PDIF, then Turtle Beach Audio Advantage Micro II is enough (as its only task is transmit DD/DTS over S/PDIF). Save your money.
post #4 of 11
If your MB has a SPDIF header, you can use this, I built a little Ion PC a while back and added this item to use digital out for music. It works great...
post #5 of 11
Another vote for just using analog, if the mobo has it. If not, no need to buy an expensive card, as others have pointed out.
post #6 of 11
If his MB has a SPDIF header, the bracket I linked to is only $11....
post #7 of 11
Thanks for the answers. The computer doesn't have in pinouts for the sound and it's only has one analog output. The receiver does have analog inputs, but I don't think the built in sound will work for that. I primarly want it for the DTS/DD. With the DTS/DD, does quality of the chips make any difference in the quality of sound? I assume playing MP3's would work with Turtle Beach usb?
post #8 of 11
Turtle Beach (or whatever cheap sound card with S/PDIF out) is just fine to send DD/DTS. MP3 has to be decoded to stereo PCM by a software player, then sent over S/PDIF. Any cheap S/PDIF device is just fine to send stereo PCM/DD/DTS.
post #9 of 11
I assumed the motherboard had at least 3 analog audio jacks. Knowing it just has the one makes me change my answer from above to whatever renethx said.
post #10 of 11
Ok, thanks for the info. I like your guide renethx. It's the best on the internet
post #11 of 11
Is there any benefit for using the analog output over the optical spdif?
Is it possible to turn up the voices on the center channel and turn down the crashes and gunfire type sounds using optical spdif or analog output?
