AVS › AVS Forum › Display Devices › Screens › New ranges of Monoprice screens seem to be coming soon
New ranges of Monoprice screens seem to be coming soon - Page 19
post #541 of 573
Originally Posted by slybarman View Post
Originally Posted by JeffKB View Post
Question for anyone who owns the multi format screen - can you mask to aspect ratios wider than 2.35? Is there enough leeway to mask Ben Hur for example?
Theoretically, you could add additional clips to catch the masking at different aspects. However, there is a limited amount of masking material on the roller.
Sent from my Galaxy Note 2 using Tapatalk.
post #542 of 573
I'm looking at the 150" 16:9 screen but I have an issue, the wall I plan on installing it on has two windows that I never use and plan on covering before mounting the screen in front of them. I'm not sure how these things mount but I just saw hiperco's post above and caught a glimpse at a possible plan killer with the way his mounted to the wall. Now the measurements between the windows are about 40" wide by 60" tall.
Will I need to downsize or am I ok? What about the dimensions of the frame for the 150 2.35 screen?
his photos of the mounting bracket
https://lh3.googleusercontent.com/-pRuKLdOkDLk/UQPqoQ2KtkI/AAAAAAAAAWU/Nn-IamtzC6U/s720/P1260064.JPG
https://lh5.googleusercontent.com/-6q1k1_IJc68/UQPqnm5_NSI/AAAAAAAAAWM/18HNzb-Cow0/s720/P1260063.JPG
the wall I plan on using, back when the builders weren't finished
post #543 of 573
i covered my huge picture windo with couple of blackout curtains stapled to wall and bolted on fixed screen. year later all is still good
post #544 of 573
I'm really just wondering how big is the part that goes on the wall
post #545 of 573
I would just mount a 2x4 across the entire wall (use some lag bolts into the studs) and then mount the screen to that. The screen would stand off the wall but you shouldn't notice it looking towards the screen.
post #546 of 573
so the mount that hiperco's post shows isn't how it normally mounts? or would I attach the black brackets to the 2x4?
post #547 of 573
My screen is the multiformat version and has a lot of aluminum frame around it to manage the adjustable masking etc. It stands out from the wall at both top and bottom. Some other types are probably more flush mount but I can't comment on those.
post #548 of 573
I have the 130" 2.35:1 screen. There is a top and bottom bracket. The brackets are approx. 62" long. So if I were you, I would mount two (top and bottom) 2x4s across the windows and then mount the brackets to the 2x4s.
Also, my screen did not come with the "straps" to mount the brackets the correct distance apart. I had to measure and figure it out on my own.
Edited by patrickmunn - 4/8/13 at 10:13am
post #549 of 573
I really want to purchase the white 106" multi format screen but monoprice won't ship to Canada, I'm having the same luck with looking for a retailer of the Grandview screen which appears to be identical. Can anyone point me in the right direction?
I did find one ebay seller "commoncoupons" that would ship the 120" screen to Canada but its not what I'm looking for.
post #550 of 573
Originally Posted by GTA Beancounter View Post
I really want to purchase the white 106" multi format screen but monoprice won't ship to Canada.
I was curious about the Monoprice screens and might recommend them to friends in Canada, so I went over to their website to have a look at the shipping issue. I added the 120" multi-format screen to my cart and received a shipping quote for Canada for $24.74. But when trying to proceed to the checkout there was a notice. Not sure why they could not put this notice a little earlier in the process to reduce frustrations.
Have you considered getting it shipped to the border?
post #551 of 573
I had the exact same experience... when I saw the $24.74 I whipped out my credit card so fast my wife would have been impressed smile.gif
Anyhow, we are looking into getting it shipped to the border as we are very close. The cost for the facility is only about $30, I just need to figure out what if any duties/tax besides our 13% HST would be payable at the border. The other issue is that I'll need to measure my wife's car to see if it will fit. On that note, can anybody who has purchased a 106" version validate that the box is about 9' x 16" x 11"? I would hate to get to the border and find out that the monoprice package dimensions are wrong!
post #552 of 573
I regularly import goods from the U.S. into Canada. Most of the time the added cost is equivalent to the HST. I find it worthwhile despite the added hassle. You can save a little money, a lot of money or get access to a product that is simply not available in Canada. If you really needed to know the exact cost you could contact the CBSA by phone.
post #553 of 573
What are the thoughts on the tab-tensioned motorized screens? I was looking at the 106" white fabric one. I am currently looking at the monoprice, visualapex, and elite screen tab tensioned 106" motorized screens for my bonus room setup.
BTW, this screen will be for a Benq w1070 projector.
post #554 of 573
Actually it will probably be an HD25 as that is what I am currently leaning towards. But so far the reviews of the motorized screen seems to be good so any others that may have run into issues please let me know as I am currently looking into getting this screen.
post #555 of 573
How is everyone's masking system holding up? After a while do these things wear down, or work as good as day one?
post #556 of 573
Still works great !
post #557 of 573
I'm really thinking of getting a 120 inch multi format screen. Were these easy to put together? Do they work well? How do they look with some dim light inte room? Not sunlight but just having a dim lighting in the back of the room kind of thing?
Looking on their site it seems 120 is the biggest multi format screen they have? I wish they had a 133 inch!
Edited by gec5741 - 11/12/13 at 12:57pm
post #558 of 573
I'm happy with mine. It is very well constructed and looks great but I wouldn't classify it as EASY to put together. It could be easy with well written directions, but they are cryptic at best. There are some good tips for assembly I early in this thread. I suggest a heavy dose of reading.
post #559 of 573
So I am thinking about getting the 120" Multi-format Monoprice screen. I read about the issues with the instruction book -- and I downloaded the PDF. Boy, I can't make heads or tails out of this thing. I am a decent DIY'er and have all the needed tools. But these instructions make no sense. Does it make sense once the screen is in front of you?
Has anyone done a video or FAQ on how to build this screen?
EDIT: Good lord! The shipping on this thing kills the deal. $165 shipped to VA. Makes the total $865 shipped. Yikes!
Edited by Skrill - 2/10/14 at 11:39am
post #560 of 573
The instructions are pretty weak. But eventually I was able to figure it out. If you can read IKEA instructions in a mirror, upside down then you'll have no problems.
post #561 of 573
I read that you had wave on the screen. Did it ever go away?
Also, I am planning to get the screen with the wall mount. Does anybody know if i could hide the power cord over the top of the case (if there is a a slanted shape) since my power outlet will be on the right side? I am assuming tensioned and non tension have same case.
post #562 of 573
No. The wave is still there. Still annoys the heck out of me but it's at the very bottom so it's not usually a distraction. Except I know it's there. This is my first screen so I can't compare to anything else. But I do really love the entire experience. Except the wave.
post #563 of 573
Any current coupon codes? I just sold my 108" DIY BOC 16:9 screen, and I'm seriously tempted by the 150" 2.35 screen.
post #564 of 573
PDAY14
5% off the entire store on orders up to $1K
post #565 of 573
Originally Posted by cr136124 View Post
PDAY14
Does this work on projection screens? I called Monoprice and asked for a price adjustment. I ordered a little past midnight. They say as a one time thing, they will do it rolleyes.gif
Edited by tractng - 2/14/14 at 1:54pm
post #566 of 573
Got the 120" tensioned motorized screen and installed last night. I wonder what this could be regarding the electric/motor. I ran a temporary extension cord to an outlet on the left side of my living room. The power worked. After cleaning up the mess in the living room, I ran the same cord over the top of the screen and connected to a different outlet. The screen won't move. I heard a click sound near the left side of the case (controls that side). Tried a few times.
Then I unplugged the cord and reconnected to the original outlet and it worked again. Then I tested with the outlet that didn't work before and it passed the test eek.gif
post #567 of 573
So without knowing the details of the motor (amp, etc) and your power panel...hard to say.
Could be your other outlet had a bunch of load on it and was low on juice the first time and did not have enough power to energize the start up of the motor.  Then perhaps stuff was turned off in your house and then you had enough power again.
Most likely the outlet that gave you issues is connected to a big load somewhere...just a guess , but it makes electrical sense.
post #568 of 573
Thanks for the feedback.
post #569 of 573
I am happy with my screen. I am got the 120" white tensioned tab electric screen. No waves or wrinkles. Yes, the screen smells bad but it is going away.
The gain on the new screen is 1.0 which I noticed my picture got a little darker vs the Carada Criterion (Brilliant white) at 1.4 gain, but the image seemed to have more nicer black color. The projector is an Epson 6500UB with 1700 hours.
On the sides of the screen near the 3 tabs from the bottom, I have some marks. Seems like the marks came from the tabs that are holding the string (when screen is rolled up). I saw a Stewart screen at Best Buys have similar markings. Does anybody notice the same with their monoprice screen.
TT.
Edited by tractng - 2/21/14 at 11:05am
post #570 of 573
TT.
My family room has high ceiling. So, I need to install the screen on the wall instead of ceiling, extending out about 6" away from the wall using a pair of long L brackets to to keep the screen in front of the TV. Is there a way I can hang the tab-tension screen case using my existing brackets?
  Back to Forum: Screens
