My rig was working fine until about a week ago. I am using a Hauppage internal ATSC tuner card and a roof mounted antenna. Using Windows 7 WMC on an Intel I-7 computer.
This new problem is that after about 10 minutes of OTA viewing on any channel, viewing will fail with a WMC "no signal" message. But the message is false. If I switch to another channel and then back to the original channel, the picture is fine.
Do you think my tuner is failing or is it something else?
Thanks for any thoughts.
