Oh the pain begins...again.
The last 2 days have been insane. We gutted our 1200sqft basement to the studs, ripped apart my theater and I am moving it to a raw space. I will lose some size but gain control. My old room, 33x20 is the new playroom for my son and the forthcoming baby.
So the plan is in place, work has begun and the whip has been cracked. The Plaster and Dry Wall boys will be here Wednesday (6 days from now) as will all my new Gear....yes NEW GEAR
The room is to be as follows---
17x14 With Double Boarded walls filled with insulation and a generous amount of green glue between the boards. All seams caulked with acoustical caulk and the ceiling will be decoupled using RSIC Clips and Drywall Furring Channels.
I have carpet (Kain Carpet "Upper Class") and paint picked out, as well as seating.
Seating looks like it will be Bello HTS.
Gear will be-
JVC RS50 or 60
Screen is a dispute but I have a weird interest in the SI Black Diamond 1.4
Marantz AV7005
Emotiva UPA7
Sunfire Cinema Ribbon Trio On-Wall - CRS-3,CRS-3C
W/ Cinema Ribbon Bi-Pole Surround - CRM-2BIP
Sunfire True Subwoofer EQ 10
Ill upload some pre-insanity pictures tomorrow...
Any ideas or suggestions are more than welcomed, they are wanted!!!
Gear will be-
JVC RS50 or 60
Marantz AV7005
Emotiva UPA7
