got my Emotiva XDA-1 : this is not a review but just a few notes:hopefully others can add reviews here
-XDA-1 was well packed: double boxed and arrived in excellent condition (except as noted below)
-No manual was included: you can download it from their site
-Remote control did not work: opened the back and reseated the batteries (batteries were pre installed) and it worked
-plugged a USB cable (the cable was 15 feet long: longer than recommended max length of 2 meters) into a WIN 7 PC and it immediately recognized the XDA-1, and installed the drivers. I selected the XDA-1 in the audio menu and hit play in iTunes and the XDA-1 played with no issues
-plugged same USB cable into a Mac mini: went into preferences/sounds and the XPA-1 appears
-Volume control worked well: no issues
- inputs switch quickly: when you come back to USB, the audio comes on almost instantly
Disclaimer: above are my observations only: I bought the XDA-1 (and XPA-5 amp) at regular price from Emotiva: I have no connection with them
