AVS › AVS Forum › Display Devices › CRT Projectors › CRT Connectivity Problem
post #1 of 2
I have a Electrohome 9500 crt
I am running my Ayre D1X DVD player through a Teranex Via SDS Output
Into a SDS card in the Projector. I am also running a Verizon Fios
Box throough a Altinex Via 5 Pin RBGH into the Projector. The sound goes through a Theta CBIII. I want to upgrade the CBIII to HDMI. And add a Blue Ray Player. I thought I could send the HDMI feed From the Verizon Box
and The HDMI feed From The Blu Ray player into the Theta -
I would then run the HDMI out into a seperate Converter box from Curt Palme using the RBGH 5 pin into the CRT projector.
Finally- Will this work running the Fios TV/Blue Ray HDMI and the DVD SDS
all into the CRT Projector. Or do I still need the Altinex . Or is there an easier way to have the TV/Blue Ray and DVD working properly.
Thank You
Jeffrey
post #2 of 2
Get the Moome VIM-HD input card for the Marquee and ditch the SDS input card. then you can go directly HDMI into the PJ from the Theta . Get the Oppo BD 93 or BD 95 as these are excellent SD DVD upscaling players and superb BD players.
Athanasios
  Back to Forum: CRT Projectors
