AVS › AVS Forum › Display Devices › Flat Panels General and OLED Technology › Sammy LN55C650 vs PN58C7000
post #1 of 2
Desperately need help to decide between the two. Considering PN58C7000 for its 2D picture quality as I am not interested in 3D. I would just buy the plasma were it not for the fact that the LCD is at least $500 cheaper than the plasma.
post #2 of 2
I will vote for the plasma due to bigger screen size and superior picture. It may be 500 more, but spread out over a couple/three years, the cost is negligible. If you are a gamer, the plasma should have less lag also. Just make sure to go easy on it for a couple hundred hours and you'll be set. I would only go for the LCD if it was a very bright viewing environment.
