Originally Posted by aaustin
Actually you want as much contact with the carpet as possible to disperse the weight of the riser over a larger surface area. If you use those bun feet then all of the weight will be concentrated onto a few very small points. By putting a piece of plywood or OSB all across the bottom of the frame you have effectively dispersed the weight over the entire size of the riser. That means less weight at each contact point with the carpet and thus less of an indent.
I think there is a math problem in there somewhere.
I might not be a math wizz but I know that the point you make is correct. Ever walk across a frozen lake and have the ice start cracking? You lay down on the ice to spread the weight so you don't break through. Same principal.Regards,
RTROSE
