Originally Posted by
Iusteve
Brad great to know. How did you find them? What is your impression of their build quality and their sound quality? Do you think they will be ok for a dedicated room? The reviews I have read have ALL been good but to hear from an actual owner of their products is priceless
Well, hard to say, as the rooms that I have them in aren't really set up with a lot of attention to audio (open concept living room connected to kitchen, dining room; hardwood floors; no acoustic treatments; no sub atm
), as its a casual living room space mostly just used for watching TV, or for a movie "until the real theater is done".
So it would be pretty hard to judge how they'd hold up in a dedicated room.
Plus although they are the same manufacturer, they aren't the same model. These are the models I used in both living room and master bedroom (except in ceilings for surrounds in the living room):
http://www.htd.com/Products/high-def...-wall-speakers
No backer boxes, I just stuffed them in the walls. With all those caveats though, I'm still happy with them. When I had the sub connected before (I may move it back now that I have the THT LP built), it made for a pretty believable HT experience, even if it isn't at all "dedicated".
Iusteve
Also notice that fancy Middle Atlantic rack that is FOR SALE......Spread the word........PLEASE??
What are you using instead?
Nice insulation - trippy how dead the room is with all the insulation in isn't it?
