Originally Posted by
COACH2369
I really like the Denon. A buddy of mine let me use his 3313 while I was trying to troubleshoot my 5508. Then I ended up using another friend's 4520 and fell in love with it. Originally I thought I would miss not having the XLR connections, but after doing some research I realized that I am not benefiting from them due to the short run I have. Plus, my ears can't tell a difference either.. The other thing that was a big plus for me was the Denon runs SIGNFICANTLY cooler and has ZERO clicking when the audio changes.
I had used the XT32 Pro on my Onkyo but for some unexplained reason, the PRO on the 4520 netted me much better results and my system sounds AMAZING now..
The 4520 has a feature called "Dialog Enhancer", which I played around with independently of the Audyssey. At first I didn't think it would do much but I set it on "low" and my wife was impressed. It boosts the center channel dialog just a hair and just enough to improve my system that much more.... It has three settings and I am sure it helps out more in systems with a "lacking" center channel.
After years of being off the Denon wagon.. this unit has me back on...
What exactly does the eShift feature bring to the table?
As a long-time Denon user, I know the satisfaction you feel. I still have my Denon AVR-4310 in my media room and it serves me very very well! That 4520 is a monster though--pretty much everything the Marantz 8801 does, but over $1k less.
Ah, eShift does 4k upscaling that significantly decreases required viewing distances. So, for folks like me who sit fairly close to the screen (about 1 screen width), it makes sure all movies look great, as opposed to holding one's breath to see if a film is authored pristinely. At my viewing distance, poorly authored discs, or even averagely authored discs don't look that great.
pcweber111
Oh snap, it's on now. You have me excited and it's not even my system.
It's onnnn like Donkey Kong!
COACH2369
Which JVC did you decide on? Have you finalized your speaker upgrade?
I'll be shooting for either one of a dealer's last few JVC-RS55 projectors at a killer deal (my ideal choice), or a RS4810 (offers eShift and improves on the picture of the RS45/46). Right now, I'm thinking of going for the Legacy Signature SE w/ Air Motion Tweeter. If I end up getting a great deal on the replacement projector, then I'll definitely be shooting for the Legacy Focus SE's or possibly the Seaton Cat-12's if I can demo them in time.
