AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Banana Plug for Marantz SR7005?
post #1 of 3
I am setting up SR7005 with Focal Chorus 8s.
Thinking about buying banana plugs as a set (20 piece)
But it seems to me that Focals have a bigger hole for bananas to be inserted than marantz.
Do i have top get different products for speakers and receiver?
What size of banana plugs, Marantz owners here use?
Are they really smaller than general or my eyes deceive me?
Thanx..
post #2 of 3
AFAIK all banana plugs are the same approximate size, and all should fit the standard 5 way binding post. How do you know the receptacle holes are bigger/smaller? Making comparisons using pictures on a website are not likely to be accurate. In the unlikely event they don't fit firmly, where are you buying from, and what is their return policy (just in case). You might contact the people at Monoprice for their advice; they also have good prices on these, in case that is not where you are buying. Or buy at RShack and return if there is a problem.
post #3 of 3
Thanx..
I don't own a Marantz (Onkyo) but these plugs are great !
Great customer service and answer emails the next day .
I thought my package got lost and they offered to send me a new
one no questions ask but the package showed up the next day.
You won't find them cheaper anywhere..be sure to check out how they work and you will see they will fit all AVR due to their design.
http://www.speakerrepair.com/mm5/mer...y_Code=locking
http://www.amazon.com/GLS-Audio-Lock...8431197&sr=8-3
