Hi folks,
I want to add a sub to my 5.1 system, but am having a hard time choosing. My budget is $500-600, and I am open to buying something used. My usage is 60/40 HT to music. The room is a very oddly shaped 700 sq ft x 10 ft high ceiling.
My system is currently comprised of DefTech speakers: BP7002 fronts (which have built-in 12 in subs powered by 300W class D amps), CLR 2002 center, and BP2X surrounds. I am using a Denon 3808ci receiver, but a plan to add a 5 channel 200 wpc amp soon and use the receiver as a pre/pro. My reason for wanting to add a sub is to get more bass extension and a wee bit more power.
The new subs in my price range that I'm looking at are the ED A5-300, Emotiva Ultra 12, ML Dynamo 500, HSU VTF-2 Mk3, and SVS PB12 NSD. For used options, I've found deals in my price range on a Deftech SuperCube 1, Paradigm PW2200, Paradigm Ultra Cube 10, and Velodyne SPL-1000r.
In terms of my priorities, I want deep base extension (20-25 hz), high sound quality suitable for jazz music, and an ability to blend well with my existing system. Size and appearance are not a concern (I am still a single man!). Power is not as high a priority for me as deep bass and sound quality, though.
Based on what I've said, do you have a recommendation? Also, are there other new subs in my price range which I should consider?
Thanks in advance!
Thanks in advance!
